VGA scanlines?
Posted: 06 Jun 2024 15:15
Hi forum,
Please can I ask for some help from your collective wisdom?
I while back I acquired an 1040STFM to relive my formative years :-)
The 1080p LCD monitor I am using does seem able to display all 3 graphics modes but I am seeing vertical "scan" lines across the whole display.
Unfortunately I do not have access to another monitor which works with the ST's output.
It is definitely more noticeable when displaying darker colours but I can see it is there even with the standard desktop.
I have tried 3 different cables including the EXXOS ST2VGA board but they all show the issue.
I've tried adding inline resistors to the R,G,B and V sync lines.
I've recapped the PSU and also tried a bench 5V PSU ( using Gotech so 12V is not needed).
I've also tried going through a VGA to HDMI box but I see the same results.
I've reseated the Shifter chip and cleaned its contacts.
Could there be something else on the motherboard causing this or is it purely a video hardware issue or is it my monitor?
Do I need to go down the OSSC route to get a better output?
Any advice would be appreciated.
Cheers
Phil
Cheers
Phil
