TF1260 EHIDE Boot Time
Posted: 14 Apr 2024 19:02
Hi Amigos,
Please can someone shed some light on my TF1260 setup, ;)
I have an A1200 with the TF1260 LC chip, 128mb Fast Ram. Im running 3.2.1 OS but since I upgraded my roms to
the custom ones from retro passion as to boot from Ehided.device, the boot time is very slow, its almost 15 seconds until i see the startup sequence flash and workbench appear.
Im using one of those right angled 44 pin IDE to SD adapters. Ive also tried my old CF card adapter and Msata drive options, all of which are reliable and work via onboard ide header or TF header, There is no ribbon cable. Im fairly sure this started once I had added the custom roms, as even when i plug the SD drive into onboard header it still takes a long time to boot. Its difficult to know exactly whats happening as of course there is no hdd activity led with the TF without further modification.
I have the latest drivers installed, TF tools and the TF drive speed is double that of the internal at around 4mbps Is it something ive done wrong or perhaps its just how it is? :roll:
Any advice much appreciated.. Thanks, Jamie :-)
