TF1260 Floppy LED weirdness
Posted: 05 Mar 2024 11:14
Is the TF1260 meant to play with the floppy LED?
Total bare board 1.d.4 (not recapped) works as normal goes to 3.1 kickstart screen with the floppy LED off
with TF1260 installed it flashes the floppy LED during boot and when it goes to the 3.1 kickstart screen the floppy LED stays on
Does the same with hdd (internal) and floppy connected... it boots from internal IDE loadmodules ehide.device, reboots and loads off the higher priority drive attached to the TF1260 IDE when it's finished booting into workbench the floppy LED stays on.
I can't test with another A1200 mobo ATM as my 1.d.1 is off getting recapped and the other 1.d.4 I have is currently dead...
