16MHz booster will work in an older STFM board?
Posted: 23 Nov 2023 19:58
Hello Exxos.
Please could you tell me if your current 16MHz booster will work in an older STFM board? It is C070523-001 REV D. I have upgraded from TOS 1 to 1.04 but the 6 chips are not from your store. I am also not bothered about Dual TOS. TOS 1.4 is fine, but I would like to go to TOS 2.06 later if possible. I have already removed the CPU and soldered on one of your 64 pin sockets. All working again with an 8MHZ CPU. There does look to be some space around the CPU, even though it is up near the floppy drive as opposed to just under the spacebar.
From what I have read so far, there's a chance this will work and a chance it won't.
Also, are your colorful 6 chip TOS 1.4 ROMS different because they can run at 16MHz instead of 8MHz? Is that the only difference? Thanks in advance. James
