Page 1 of 1
Force cold boot / more thorough reset?
Posted: 20 Sep 2023 18:12
by Cwiiis
Is there a way to force a cold boot on the ST?
The reason I ask, some games on pp's hdd game collection seem to setup the mmu so that TOS thinks there's only a meg of RAM and this persists across a reset. I wouldn't mind (that much) flipping the power switch, but that doesn't actually seem to get me a cold boot on my ST, presumably because the caps take a long time to empty or the ACSI hdd drive I have plugged in with external power ends up keeping some part of the ST warm? Completely unplugging everything and plugging it back in gets me a cold boot, but that's pretty cumbersome.
Perhaps my real question is, is it possible to reset things so that any mmu tinkering that has happened gets reset?
Re: Force cold boot / more thorough reset?
Posted: 20 Sep 2023 18:29
by stephen_usher
If you're running TOS 1.04 or later then Ctrl-Alt-Shift-Del should do it.
Posted: 27 Sep 2023 16:35
by Cwiiis
stephen_usher wrote: 20 Sep 2023 18:29 If you're running TOS 1.04 or later then Ctrl-Alt-Shift-Del should do it.
Thanks, this does the job! Only thing worth noting is that it has to be right-shift, left-shift funnily makes the combination not work at all...
