[Video] New Falcon auto-byte-swapping IDE adapter (enhanced twisted cable)
Posted: 18 Jul 2023 10:17
by Badwolf
Morning all.
I've made a second version of my byte-swapping IDE adapter for the Falcon which this time has some smarts in it.
The idea is data bytes are swapped but register and disk information bytes are not.
This means, if you use HD Driver's dual TOS/Windows partition mode, you can pull your SD/CF card out of the Falcon, slap it into a Windows or Mac (although not Linux ATM) and access your files directly on the desktop. Very useful for deploying Bad Mood, Basilisk II CDROM images or even just setting up MiNT configuration files, for example.
You can already do this with PP's PC-partition supporting IDE driver, but you can't autoboot that. Or EmuTOS, but that doesn't support 16 bit colour modes yet. Also both of those solutions suffer a slow down because of the logical (software) byte swap that's needed.
This adapter gives you the ability to auto-boot as normal, run in TOS as normal and not suffer the slow-down of logical byte swapping. It's similar to the "smart swap" technique Christian's Thunder, Lightning and TwiSTEr boards offer, although developed independently and not related.
Anyway, have at it. I don't promise it'll work with ATAPI or anything more complicated than the exact use case I've described in the video, but it's all open source, the firmware is there to inspect and upgrades and additions are obviously welcome.
Re: [Video] New Falcon auto-byte-swapping IDE adapter (enhanced twisted cable)
Posted: 18 Jul 2023 11:35
Oh nice. Might allow me to finally get files from my PC to Falcon CF without stuff screwing up ?
Trudie also has "smart swap" :) Just makes life sooo much easier. Really need to finish the production batch off, never enough time.
Posted: 18 Jul 2023 11:41
by Badwolf
exxos wrote: 18 Jul 2023 11:35
Ought to, although probably requires starting again if your card isn't already dual-compatibility partitioned. You might find a smiliar-shaped item in the box that's on its way to you at the moment. ;)
Oh cool. Didn't know that, else would have mentioned it.
Posted: 18 Jul 2023 11:55
by alexh
Looks cool. Thanks for the hard work.
For solid state drives (at least the ones I design) getting the data in the correct order will probably help with reliability.
Posted: 19 Jul 2023 11:45
Badwolf wrote: 18 Jul 2023 11:41
:D :D Hopefully can pick it up at the weekend.
Posted: 20 Jul 2023 10:04
by troed
Saw the video - nice work. Do you have additional details as to why Linux doesn't play ball?
/Troed
Posted: 20 Jul 2023 15:12
by Badwolf
troed wrote: 20 Jul 2023 10:04
/Troed
No. My guess is that the compatibility trick relies on something that Windows tolerates but Linux doesn't. Linux detects nonsensical partition sizes.
Now this I've not tested for a while, but IIRC Linux actually suports AHDI Atari-format partition so if you want to use Linux, you don't need the Windows compatibility mode in the first place.
Didn't think about that during the video shoot.
Posted: 07 Aug 2023 13:22
by Steve
Just built up mine this morning! I've used pin headers for all the connectors since I'm not using the same kind of SD card solution BW is, I'll use very short IDE cables instead. Hopefully that'll be ok.
Next, programming it :)
Big thanks to Badwolf!
Posted: 07 Aug 2023 13:54
by tOriman
Hi,
Nice piece of hardware :) Thank you. I find it useful.
tOri
Posted: 07 Aug 2023 17:24
by Steve
I had lots of trouble getting the CPLD programmed! So odd! I basically just tried three of four times in a row and eventually it worked? So strange.
