Page 1 of 5
Kicad conversion of the Thomson MO5
Posted: 29 May 2023 21:26
by sporniket
To change a little from the ST world, I started to convert into Kicad the Thomson MO5 computer, for now the v1 board (there are a v2 and v3 boards, that I plan to do later provided I am able to get one of those)
For now the schematic is done, and like the ST, I plan to remake the PCB. (This is one of my summer projects, along with the remake of the 260/520ST).
People can get the schematic in a nice PDF here :
https://github.com/sporniket/kicad-conv ... .0.0-alpha
Re: Kicad conversion of the Thomson MO5
Posted: 03 May 2024 10:41
by sporniket
Last month, I finished to replicate the PCB ( see there :
https://github.com/sporniket/kicad-conv ... 0.0-beta-1 for all the files), and I received it today.
There are some little details to fix, but mecanically, it perfectly fit inside the case, and the mounting screws are at their expected locations. I need to do further check on the electric and mecanical side now.
- 2024-05-03--0-it-fits.jpg (205.51 KiB) Viewed 3302 times
Posted: 03 May 2024 13:10
by HigashiJun
Well done !
Just kidding, but Fabius would be proud of you.
:lol:
Posted: 03 May 2024 19:21
by sporniket
HigashiJun wrote: 03 May 2024 13:10
:lol:
So true :D
Posted: 29 Jul 2024 12:00
by sporniket
This summer, I try to do an assembly, the goal is obviously to have a working computer as a proof of a correct remaking. The original computer will serve as donor board for the ICs, and especially the gate array (this is a Motorola MC1300 on a custom support, I will have to desolder it ; later iterations use an EFCIS gatearray in PLCC package put in a socket, more friendly).
Thus I ordered a big set of components :
- 2024-07-18--summer-project-in-bulk.jpg (59.87 KiB) Viewed 2925 times
Then I grouped them by type :
- 2024-07-19--01-resistors-and-ceramic-capacitors.jpg (77.2 KiB) Viewed 2925 times
- 2024-07-19--02-electrolytic-capacitors-transistors-diodes-inductances-cristal.jpg (78.6 KiB) Viewed 2925 times
- 2024-07-19--03-ic-sockets.jpg (62.03 KiB) Viewed 2925 times
And now I have started, first with most of diodes (the small ones, there is a power diode that will be put later, as it is big and have to stay at least 1cm above the PCB).
- 2024-07-28--diodes.jpg (197.07 KiB) Viewed 2925 times
Then the resistors
- 2024-07-29--02-done-resistors.jpg (280.83 KiB) Viewed 2925 times
To be continued...
Posted: 30 Jul 2024 09:34
by sporniket
Done installing IC sockets.
- 2024-07-30--01-ic-sockets-done.jpg (268.05 KiB) Viewed 2895 times
!Message from: Moderator
@sporniket, we have placed your attachments in-line so they display correctly in your post. Here's the
how-to guide.
Posted: 30 Jul 2024 12:25
by HigashiJun
Looks good !
(And probably better than the original...)
Posted: 30 Jul 2024 22:17
by sporniket
The original board shows its age, espacially the underside where large copper pours have a wavy texture.
But the traces follow a quite clean orthogonal routing.
Posted: 31 Jul 2024 00:43
by HigashiJun
Now if you find a mechanical keyboard for your machine (instead of the ugly chiclet keyboard...) and a good case, you will have a nice retro in your collection.
:D
Posted: 31 Jul 2024 15:02
by sporniket
This build will just use the case and keyboard of the donor computer. The rubber keyboard is not the best, but it's part of the nostalgia :) . I did not know about the "mechanical" keyboard version until I rekindled with that family of computer.
Today's progress : first adding the non polarized capacitors, as well as the cristal and the coated inductance :
- 2024-07-31--01-capacitors-inductance-cristal.jpg (277.64 KiB) Viewed 2820 times
...then adding the transistors and the electrolytic capacitors...
- 2024-07-31--02-transistors-electrolytic-capacitors.jpg (261.62 KiB) Viewed 2820 times
And the next step will be pulling all the chips from the donor board.
I have also prepared (not soldered yet) a socket for the gate array by hacking some DIP double-swipes sockets (get individual rows and sanding the ones that are on the inside.
- 2024-07-31--03-experimental-plcc-staggered-double-swipes-socket.jpg (83.34 KiB) Viewed 2820 times
It would be nice if the gate array is happy with it. I also have turned pins stripes, but it is more a hassle to use, so it's my fallback plan.
