Page 1 of 1
ROM speed suitable for H5?
Posted: 19 May 2023 16:12
by Steve
I am just wondering, since EmuTOS keeps getting updated (and I like to keep up to date if possible) Do I need to keep writing one-time-programmable 27c4096 chips (55ns) or will the H5 be happy with 120ns 27c4096acc-12 UV erasable roms?
ps - as a side question, is there any such thing as an e-eprom variant that doesn't need UV erasing?
Re: ROM speed suitable for H5?
Posted: 19 May 2023 16:22
The H5 will work fine with any chips. You do need 100ns if using the 16MHz booster. 55ns is for the STE when running 32MHz.
Things will be easier if I ever get flashy clock finished :roll:
Posted: 19 May 2023 17:07
by Steve
exxos wrote: 19 May 2023 16:22 The H5 will work fine with any chips. You do need 100ns if using the 16MHz booster. 55ns is for the STE when running 32MHz.
I'm using the TOS Decoder (your little one which can also be a 16mhz booster) & TF536 50mhz 030 - will that be ok for 120ns?
Posted: 19 May 2023 17:09
Steve wrote: 19 May 2023 17:07 I'm using the TOS Decoder (your little one which can also be a 16mhz booster) & TF536 50mhz 030 - will that be ok for 120ns?
Should be.
