Page 1 of 2
PHIHONG PSM-5341: blown (?) resistor R35
Posted: 10 Apr 2023 12:03
by wolfman
Hi @all,
just to doublecheck:
I have a PSU (PHIHONG PSM-5341) working absolutely fine.
Voltages are OK, PC111 is in place - so far so good.
I decided to open the case (metal shielding) to inspect the PCB and found a burned resistor R35.
- burned R35
- IMG_20230410_124209.jpg (77.07 KiB) Viewed 1954 times
According to the schematics this is a 10 Ohms resistor - and the funny thing is: my multimeter shows 10 Ohms for this resistor.
I can't read the colorings on the resistor anymore...
My plan is to replace the existing fan with a Noctua NF-A6x25 FLX.
The previous owner has soldered a 280 Ohms resistor to the fan-header...
Re: PHIHONG PSM-5341: blown (?) resistor R35
Posted: 10 Apr 2023 12:50
Posted: 10 Apr 2023 12:59
I found it..
- Capture.PNG (13.16 KiB) Viewed 1941 times
Probably better to replace it with a slightly higher wattage value as it is only driving the fan anyway.
Posted: 10 Apr 2023 13:08
by wolfman
exxos wrote: 10 Apr 2023 12:59
I assume the existing one is a 1/4 Watt?
What wattage would you suggest?
Posted: 10 Apr 2023 13:19
wolfman wrote: 10 Apr 2023 13:08
I would assume so yes.
It really depends what fan you are putting in there.
The Noctua NF-A6x25 FLX fan you suggest pulls 1.44watts max according to the specification. So you will probably need a 2 W resistor in that respect otherwise it will burn out just the same.
Posted: 10 Apr 2023 13:46
by wolfman
exxos wrote: 10 Apr 2023 13:19
Thanks for the infos!
The existing fan pulls 12V/0.16A and has soldered a 280 Ohms resistor in serial.
No wonder that a 1/4W resistor can't handle that load...
Posted: 10 Apr 2023 14:51
wolfman wrote: 10 Apr 2023 13:46
12V/0.16A is almost 2 watts.
280R resistor will limited the current to about 54mA to the fan and "burn up" the other power in the resistor. Or about 0.650 watts.
I assume whoever fitted the 280R resistor wanted to half the power to the fan. But even that would probably end up being like 1 watt.
Either way, A 1/4watt resistor being 0.250watts isn't going to like it. But I think you already figured that part out :lol: :fire: :hide: :fire:
Posted: 10 Apr 2023 18:59
by Steve
@wolfman please be careful, I put a Noctua (probably the same model) in my TT, I put it on the quietest setting, shortly after a MOSFET blew in the PSU and sent 7v down the 5v rail in my TT. I was very lucky it didn't do permanent damage.
Recently @mikro I think did some investigation about some of the MOSFET temperatures in the TT PSU and one was regularly running at 89 degrees C, which apparently is normal. But if you lower the cooling it will easily go over its 100 degree maximum.
I have my Noctua in still, but I run it at the high speed setting.
Posted: 10 Apr 2023 19:42
by wolfman
exxos wrote: 10 Apr 2023 14:51
;-) yolo?? living on the edge??
Posted: 10 Apr 2023 19:44
by wolfman
Steve wrote: 10 Apr 2023 18:59
Good to know: I planned to put the fan to the "middle" setting - but I think a Noctua fan is quiet enough running full speed.
