TF1230 and 3Com PCMCIA Ethernet
Posted: 17 Jan 2023 18:42
My A1200 with TF1230 has been working fine since september 2021 but I have recently run into an issue, I cannot get a 3Com ethernet card to work although it works fine when the TF1230 is removed so wanted to see if anybody is using a 3Com card and TF1230 without issues.
I bought a 3Com 3C589D PCMCIA ethernet card, installed roadshow and 3c589.device and plugged in the card. I can connect to the network but cannot use DHCP, with a manual IP address, I get a connection but a lot of packet loss when pinging and no program is able to receive data even on my local network.
I have since tried another 3C589D and a 3C562 card but all three act in the exact same way.
I did have a prism2 WiFI card working a few months ago and a CF adapter works fine for copying files so PCMCIA seems at least somewhat fine.
Have tried both Roadshow and MiamiDX, clean OS3.2 install, 3 different cards, 4 network switches including a 10/100 switch in case it helped with auto negotiation. I isolated just the Amiga and my laptop from the rest of the network in case another device was causing an issue on the network.
The only thing that has worked was removing the TF1230 from the amiga but that's not much of a solution.
A1200 1D.4 recapped in 2020 and timing fixes done. OS3.2 ROMs. TF1230 is running the latest firmware.
The only other hardware is a ScanPlusAGA, can't try without that yet, only have access to screens with VGA or HDMI right now.
Is this just a me problem or has nobody tried a similar setup?
