As documented elsewhere, I picked up an STFM motherboard for testing DSTB1 & likely other projects.
It's not in great nick -- more on that anon -- but for starters I needed a socketed 68k slot. After a bit of inspection, I decided the snips had to come out. Here's how I did it:-
Re: [Video] Socketing the 68k on an STFM
Posted: 27 May 2022 06:50
by zChris
Very interesting to see how one can do it. I myself failed miserable in removing 68k cpu :P Without any bigger knowledge i tried to remove the solder with a soldergun and it went as expected :|
/zChris
Posted: 27 May 2022 07:03
by stephen_usher
It depends upon your desoldering gun and technique.
I removed mine with my Hakko quickly and without any difficulty. The CPU just dropped out.
Posted: 27 May 2022 07:49
by zChris
Interesting! Did you do any special prework to make it suck ALL the solder?
Posted: 27 May 2022 08:09
by stephen_usher
Generally just add new solder (making sure that all the old solder has fully melted), flux,and leave the gun on the joint for a few seconds (and rotate the bit on the pin until it moves freely) before pulling the trigger to suck, and continue to such and rotate for a few seconds before removing the bit and finally taking the finger off the trigger (after removing it fro the surface).
Also, if a pin is being difficult, more flux and resolder before trying again, holding the tip on the job a bit longer and sucking for more time and wiggling the pin more. :-)
If this doesn't do it then you need a hot air station to heat the legs on the component side until the solder melts and lift *gently* with an electrical screwdriver until it starts to move, then lift.
Posted: 27 May 2022 08:55
by zChris
Alright, how hot do you use? My soldering gun is on 400 degrees, maybe thats too hot.
Posted: 27 May 2022 09:44
by stephen_usher
Usually I use about 350C, but you need to keep the gun moving continuously so as not to overheat any one part of the board.
Posted: 27 May 2022 10:40
by agranlund
If I ever where to remove a 68k again I'd probably go that route too :)
When I socketed mine I didn't want to destroy the CPU so I bought myself a desoldering station believing it would make everything super easy..
In hindsight I probably should have practiced on something else first.. it ended up a success in the end but it was quite a hassle to get there, most likely due to my poor technique :)
Posted: 27 May 2022 11:05
by Icky
@agranlund you mention a desolder station I found a desolder gun helped to removed the main pins solder but it was not so good at the GND and VCC pins. Thats where I used @stephen_usher's method of heat gun on those pins. Overall the CPU comes out nicely and unscathed.
Posted: 27 May 2022 12:08
by Badwolf
zChris wrote: 27 May 2022 06:50
I know the dilemma. I really wanted to preserve the chip, but I caramelised my first revision of DSTB1 trying to desolder just one 32 pin header strip.
