Page 1 of 4
Xilinx programming cable USB -- anyone got this one?
Posted: 13 May 2022 20:30
by Badwolf
I've been trying to help Frank get his Xilinx programmer working so we can try to work on some trouble he's having with his DFB1.
He's got a knock-off programming cable labelled as DLC9LP and with the following in lsusb:-
Bus 001 Device 008: ID 03fd:000f Xilinx, Inc.
Now 03fd/000f isn't listed in my copy of xc3prog, but we've tried setting it up as "xpc" (as that was the closest with 03fd/0008) via a cables database text file to no avail.
Does anyone have one of these matching these VIP/PID settings & know how to get it to work?
Ta,
Re: Xilinx programming cable USB -- anyone got this one?
Posted: 13 May 2022 20:46
by czietz
This post indicates that 03fd:000f is one of the PIDs the cable can have when it expects the user to load the firmware to the cable:
https://github.com/timvideos/litex-buil ... nder-Linux
Posted: 13 May 2022 21:17
by Elethiomel
If you can't get stuff working, using a raspberry pi with a few jumper cables has worked very well for me
https://linuxjedi.co.uk/2021/11/25/revi ... pberry-pi/
Posted: 13 May 2022 21:25
by frank.lukas
Problem is I have not a pi and my PC had win7 and Ubuntu 15.04 on it. I can not install xc3sprog onto Linux because I can not upgrade to a newer version the PC is a 32bit one. So I must work with windows 7 ...
Posted: 13 May 2022 22:26
by Badwolf
czietz wrote: 13 May 2022 20:46 This post indicates that 03fd:000f is one of the PIDs the cable can have when it expects the user to load the firmware to the cable:
Oh my word!
Thanks, Christian. That looks an absolute pain.
Posted: 13 May 2022 22:27
by Badwolf
frank.lukas wrote: 13 May 2022 21:25 Problem is I have not a pi and my PC had win7 and Ubuntu 15.04 on it. I can not install xc3sprog onto Linux because I can not upgrade to a newer version the PC is a 32bit one. So I must work with windows 7 ...
Looking at the instructions Christian posted, it might be easier, quicker and cheaper to get a Pi ZeroW!
Posted: 13 May 2022 23:15
by troed
This is what mine presented before it had been initialized (firmware uploaded? Don't remember).
Wasn't a big deal to sort out.
Posted: 14 May 2022 08:23
by czietz
Badwolf wrote: 13 May 2022 22:26 Thanks, Christian. That looks an absolute pain.
Hm, isn't it just one single command ("fxload ...") that Frank needs to run to load the firmware into the cable?
Badwolf wrote: 13 May 2022 22:27 Looking at the instructions Christian posted, it might be easier, quicker and cheaper to get a Pi ZeroW!
Looking at the worldwide(!) availability (or rather: non-availability) of Pi Zeros I doubt that: https://rpilocator.com/?cat=PIZERO
Posted: 14 May 2022 10:06
by Steve
czietz wrote: 14 May 2022 08:23 Looking at the worldwide(!) availability (or rather: non-availability) of Pi Zeros I doubt that: https://rpilocator.com/?cat=PIZERO
Only if you buy new, I'm sure Frank could find one in local ads like Facebook market or Gumtree. There are *lots* of people who purchased a Pi for a project but never used it.
Posted: 14 May 2022 16:13
by frank.lukas
When WIN7 boots, the red status LED on the USB cable lights up. I installed Labtool and the USB cable is recognized there, there is no message that it was not found, so I assume that it is recognized. But there is an error message that UREF is not there. I think I killed the USB cable at the very beginning because it also smelled like burnt electronics.
What is the exact way of proceeding when flashing?
A Rasp Pi is too expensive for me. I bought a USB CJMCU FT232H module and am trying it. Otherwise I have to send my Falcon mainboard plus DFB1 to England.
