Page 1 of 1
Falcon 030 PSU kit
Posted: 25 Mar 2022 06:39
by HomeLate
Hi,
I recently ordered two Falcon 030 PSU kits but each kit is missing a 47uF capacitor for replacing two 47uF and one 22uF capacitor. Can you pm which 47uF type I should order?
Re: Falcon 030 PSU kit
Posted: 25 Mar 2022 14:16
by mikro
This can be helpful:
https://www.atari-forum.com/viewtopic.p ... 36#p313110
Btw the voltages are not that important, most (if not all) capacitors are hooked on the 5V branch so even caps rated at 6.3V shouldn't give you any trouble.
Posted: 30 Mar 2022 13:25
by HomeLate
Thanks @mikro. I used this list to recap my Falcon's. But the psu seems more urgent so I bought two Falcon PSU cap kits from Exxos.
Posted: 30 Mar 2022 14:13
Well the shop just says ripple filter capacitors but the original capacitors that you are replacing with the items from the kit will have the voltages written on them. As long as the replacements are the same voltage or higher you'll be fine.
