Page 1 of 3
Compatible VRAM memory
Posted: 03 Mar 2022 20:14
by Steve
Hiyas...
I have a Mach32 board that has two sockets for upgrading to 2mb vram.
The chips on the board are: HM514170AJ8
I had some Oki M514265BSL chips which I thought were the same kind, but they don't seem to work/allow higher resolutions.
Can anyone help me find/identify compatible ram chips? Much appreciated,
ps - I did find an ebay seller in the UK (little diode) and they want £24 for 1x chip!!! Can you believe it?
- PXL_20220303_195635751.jpg (518.57 KiB) Viewed 3480 times
Re: Compatible VRAM memory
Posted: 03 Mar 2022 20:24
by PhilC
@Steve are you sure the ram is plug and play and you don't need to jumper something on the board or blow a new eprom?
Posted: 03 Mar 2022 20:25
by Steve
I just found a picture of
@frank.lukas 's old card and noticed one thing! There is one extra resistor bridge/jumper below the ram which my card doesn't have. I wonder if it needs this to enable the extra ram banks.
- nova.jpg (166.48 KiB) Viewed 3473 times
Posted: 03 Mar 2022 20:27
by Steve
My card:
- PXL_20220303_202634922.MP.jpg (571.53 KiB) Viewed 3472 times
Posted: 03 Mar 2022 20:33
by Steve
@PhilC I think it might be a case of adding a 100ohm resistor, I'll try it out.
Posted: 03 Mar 2022 20:47
by Steve
@PhilC update: no didn't work ;D
Posted: 03 Mar 2022 20:49
by PhilC
Steve wrote: 03 Mar 2022 20:47
Oh well, was just a thought
Posted: 03 Mar 2022 21:54
by frank.lukas
There is no need to change anything. Insert the Ram and thats all. Test your card in a isa dos pc with the mach32 utility ...
Posted: 03 Mar 2022 23:41
by Steve
Ok, tuns out the ram I put in is EDO and I need FPM memory. I'll try and track down the right stuff.. @frank.lukas I noticed on that old photo of your Mach32 it seemed to have NEC memory but it is too blurry to read. Would you know the number for those chips anymore? Thanks
Posted: 04 Mar 2022 07:14
by frank.lukas
my card was different ...
https://forum.atari-home.de/index.php?topic=14398.0
- 1mb_dram_mach32.jpg (270.84 KiB) Viewed 3378 times
