surprise STF refurb
Posted: 22 Feb 2022 04:36
So a couple weeks ago I picked up the STF I mentioned in this thread. That PSU is long gone, and I've jury-rigged a Meanwell RD50A for power. I bought this as untested, and I'm poking it to determine if it'll be a salvage, or a donor. Waaay on the backburner, I have my H5 board that I'd like donor parts for, and I don't want to tear up a working machine.
Things are rarely so binary though, and this machine might be close to working.
At the moment, I occasionally get many bombs (20+) on boot, OR, the system boots to desktop but it doesn't read the floppy correctly. It reads some filenames but with garbage appended, and says 0 bytes are used on the disk. The disk itself is good, and the floppy drive is good: I can drop both into another machine and they're healthy. So I've eliminated those as the likely problem.
So I guess maybe the floppy controller is at issue? It looks like somebody's played with it before -- I don't imagine these were originally socketed -- but that might just mean they tried to replace and the problem persisted.
But from there... I'm not really sure how to debug this issue. This is a TOS 1.0 machine (which I'm enjoying, because I've never had one before), but one of the TOS chips has been replaced.
That suggests there was a (suspected) ROM issue in the past, too?
So, I'm curious what folks reckon. Is it a bad ROM which I'd fix by dropping in 1.4 anyway, or a bad WD1772, or a bad joint on the socket, or something else? I haven't touched any mandatory fixes on this yet, fwiw, so those are all up for grabs too.
