Poorly Atari 1040STE
Posted: 11 Dec 2021 23:15
Hello Everyone,
I'm getting used to posting on here after all my troubles with my machine.
Firstly, I got the Dual TOS switcher and during extracting the TOS roms a track was lifted. I then discovered that there was another pad that had lifted that I hadn't seen. I installed the dual TOS switcher and put right the tracks that had been broken by way of 'bodge wire' on the underside of the motherboard.
Since then I haven't been able to get the machine to boot up at all. Then my power supply went BANG! so I've got and installed the new PSU from Exxos and new switch for the back. All wired up and everything good, however I'm getting a blank white screen. I'm not getting any blips from the keyboard at all no sound from the thing at all.
W102 - W104 are linked in spaces 2&3 as normal. These have never been changed.
I'm at a loss now as to what to try. I've done some investigative work using schematics and have tested continuity of all address lines and data lines from the TOS Switcher (HI & LO ROMS U102 & U103) to the following IC's:
U100 - MC68000_PLCC
U101 - ST_BLITTER
U200 - MC6850
U202 - YM2149
U203 - MC68901
U300 - ST_DMA (DIP40)
U400 - STE_GSTMCU
U401 - STE_GSTSHIFTER
U509 - U512 - 74LS244
U632 - 74LS244
Everything checks out and there is continuity everywhere from the TOS Switcher board. I've checked the voltages too and they are all ok too. 5.11v on the board.
This machine was working perfectly until I changed the TOS roms. It's like the processor can;t understand the TOS and is stuck in a loop cycle and unable to boot up.
If anyone has anything else they can add that I can have a go at and see if I can resurrect this machine I would be grateful.
Regards,
Brett
U100 - MC68000_PLCC
U101 - ST_BLITTER
U200 - MC6850
U202 - YM2149
U203 - MC68901
U400 - STE_GSTMCU
U632 - 74LS244
Regards,
Brett
