Page 1 of 2
Wanted: old heavy 3.5" short button floppy
Posted: 20 Oct 2021 13:57
by thesofa
I am looking for a NON-WORKING old heavy 3.5" Atari short button floppy disc drive to use as a floppy emulator case in my ST. I live in UK and I am happy to pay postage.
Re: Wanted: old heavy 3.5" short button floppy
Posted: 20 Oct 2021 14:56
You just bolt the emu drive in ? Or did you mean a external case ?
Posted: 20 Oct 2021 15:19
by thesofa
I mean an internal one but it has to be the one with the cast base. I remove all the gubbins from the inside of the drive, then cut off the back plate after i have drifted out all the brass support pins from inside, then file off the hooks for the springs and the L shaped support , then I plan to file the inside flat then drill support holes for the emu and make some support bases for the card and fixing.
Maybe its time for some pix?
- Underside of floppy chassis
- underside.jpg (289.56 KiB) Viewed 2967 times
and the top view
- Stripped tiop view showing parts to remove
- topside.jpg (266.26 KiB) Viewed 2967 times
ater trimming of projections from inner face
- End removed and base filed flattish
- after trimming.jpg (279.59 KiB) Viewed 2964 times
Posted: 20 Oct 2021 16:26
by thesofa
Sadly it seems i have wasted my time, there is not enough height room to get the emu board into the case and still have room to get the USB connector into the emu board.
So please forget my request foe old floppy drives.
Next try is some aluminium plate i have lying around, watch this space!!!
Posted: 20 Oct 2021 16:29
by PhilC
If you have a 3d printer then there are a few STL files on Thingiverse that will allow the PCB from a Gotek board to fit into an ST
https://www.thingiverse.com/thing:2664753
Posted: 20 Oct 2021 16:43
by Badwolf
I'm confused as to what you're trying to do: my STE (short button) holds a Gotek completely unmodified.
Posted: 20 Oct 2021 16:58
by thesofa
Posted: 20 Oct 2021 17:01
by thesofa
Badwolf wrote: 20 Oct 2021 16:43
Yes I know it will but I do not have a Gotek as I am trying to fit one of these
https://www.simulant.uk/shop/computer-a ... ek-upgrade
and also avoid cutting the case up too much.
Besides, I like playing with metal!!
Posted: 20 Oct 2021 17:15
by Badwolf
thesofa wrote: 20 Oct 2021 17:01
The link prominently shows Goteks. :)
I assume you mean you just have the bare board?
Perhaps have a look on Thingiverse for the 3D-printable STLs and just copy one of those, but in aluminium! :P
Posted: 20 Oct 2021 18:29
by PhilC
Thread has been locked and last two comments removed.
Comments had seemed sarcastic in nature, which we try and avoid on this forum.
