Page 1 of 2
Black vertical lines on ST
Posted: 10 Sep 2021 12:05
by Steve
Hey guys,
Just hoping for some pointers on this. At first I thought it was a RAM issue but the memory test passes fine on diagnostics and on YAART. Machine is an old rev B ST. Any ideas? Thanks
- PXL_20210909_103311924.jpg (379.95 KiB) Viewed 3384 times
- PXL_20210910_110658889.jpg (729.07 KiB) Viewed 3383 times
- PXL_20210910_110242253.jpg (568.67 KiB) Viewed 3384 times
Re: Black vertical lines on ST
Posted: 10 Sep 2021 12:13
by czietz
I recently helped solve a similar issue:
https://www.atari-forum.com/viewtopic.p ... 63#p421063. (Of course, in your case it won't be exactly D10, but another data line.)
Posted: 10 Sep 2021 12:17
by Steve
Thanks @czietz I'll check it out!
by stephen_usher
Looks like a Shifter issue.
Posted: 10 Sep 2021 12:19
by czietz
PS: Looking at the pattern on your photo, I suspect D3.
Posted: 10 Sep 2021 12:38
Machine would not boot like that if it was a RAM fault, you basically have one data bit low all the time. I would check out the databus to the shifter or re-solder it etc.
Posted: 10 Sep 2021 13:52
by PhilC
exxos wrote: 10 Sep 2021 12:38
@Steve That makes sense considering the other stuff we found.
Posted: 12 Sep 2021 19:09
by Steve
Hi guys,
I've checked D0 to D15 going to U22/26/23/27 pins, everything seems to be connected fine (buzzed them all) I also swapped out all chips U22/26/23/27 with different ones. I also swapped the shifter, still the same.. hmm what am I doing wrong?! :D
Here's a picture of the lines I've buzzed (highlighted in green spray paint) they all seem fine:
- Screenshot from 2021-09-12 19-02-47.png (377.13 KiB) Viewed 3301 times
Posted: 12 Sep 2021 19:19
by PhilC
@Steve ok so all the lines buzz out ok, good. Now stick your scope on them one by one and one of them is likely staying low, hence the black line.
Posted: 12 Sep 2021 19:20
by DoG
Check other side of U22, U23, U26, U27.
