Page 1 of 2
Two Rev B ST's with different shifter bodges
Posted: 11 Aug 2021 19:16
by Steve
Hi people,
I've got two faulty ST's, both Rev B ST's. On the rear of the shifter socket they both have different resistor/capacitor bodges, can anyone here clear up which is correct for this revision?
Image 1:
Shifter: C025914-38 / PH23-023 CAP
1k resistor (Shifter pin 1 to GND)
capacitor: yellow violet black gold black (Shifter pin 21 to GND)
Image 2:
Shifter: C025914-38A / PH23-024
capacitor: yellow violet black gold black (Shifter pin 11 to GND)
Thanks,
For orientation, ram is at the bottom of each photo.
- PXL_20210811_170657698.jpg (522.22 KiB) Viewed 2944 times
- PXL_20210811_170645496.jpg (469.98 KiB) Viewed 2944 times
Re: Two Rev B ST's with different shifter bodges
Posted: 11 Aug 2021 21:30
by frank.lukas
Image1: a single resistor 1k or 10k? and a capacitor
Image 2: only one capacitor
I think original Atari factory hardware mod ...
What are the Shifter Pin numbers? IMP or normal chipset?
Posted: 12 Aug 2021 11:14
by Steve
Thanks @frank.lukas
Ah yes.. sorry I always forget these are capacitors.
Image 1:
Image 2:
Posted: 12 Aug 2021 13:13
by frank.lukas
See the schematics ...
Posted: 12 Aug 2021 13:25
Steve wrote: 12 Aug 2021 11:14
Seem normal (10K on the H5 in fact)
BLUE bit 2... Odd to have capacitors in the blue line like that, maybe it was just inherently more noisy on that colour :shrug:
/LOAD. Again probably noise.
Overall by the looks of it, these bodies are probably just tailored to whatever board has whatever problem after manufacture.
Posted: 12 Aug 2021 13:39
by frank.lukas
4 7 x1 5% ?
47pF
Posted: 12 Aug 2021 13:49
by Steve
Ok, thank you guys. So it seems they're perfectly fine to keep as-is.
Posted: 17 Aug 2021 19:52
by Steve
Just as a follow up to this thread I decided to try these capacitors on another ST with poor video output:
- PXL_20210817_184633045.jpg (495.78 KiB) Viewed 2801 times
- PXL_20210817_180336995.jpg (251.48 KiB) Viewed 2801 times
- PXL_20210817_184808206.jpg (424.23 KiB) Viewed 2801 times
But even after applying these capacitors nothing changed and the video output is still poor, with all those vertical white and black dotted lines. Does anyone have more suggestions on what else I could try to smooth out the image quality / reduce noise?
Posted: 17 Aug 2021 20:32
Its a inherent problem which a lot of early STs suffer from :? All you can do is add something like 10uf ceramics on the power on the shifter and rgb drivers and 47pf from RGB on the video connector to gnd.
Posted: 18 Aug 2021 15:05
by Steve
exxos wrote: 17 Aug 2021 20:32
Okay cool, just to clarify for my feeble mind:
- 10uf ceramic on Shifter 5v pin to GND
- RGB drivers, are these Q5,Q4,Q3,Q2 transistors? If so am I connecting 10uf from base/or/collector/or/emitter to gnd on each one?
- With the 47pf, is that three 47pf's, one on each line R,G,B connected to gnd. At the video connector.
thx
