Page 1 of 1
Help with resistors in parallel
Posted: 01 May 2021 21:16
by Steve
Hey guys,
If I replace a blown resistor with 2x resistors in parallel, would this allow them to be more tolerant to the heat / wattage passing through, ie share the load?
So for instance, if the original resistor that blew was 500ohm, I would put 2x 1kohm resistors in parallel right? But yeah, would this be effective and make it more reliable? (of course I know you can get higher wattage resistors, but if you don't have any etc would this work)
Cheers
Re: Help with resistors in parallel
Posted: 01 May 2021 21:38
by bfollowell
Yes, in your example, two 1Kohm resistors in parallel would be equivalent to a 500ohm resistor. I have no idea how tolerant the combination would be in relation to heat or stress compared to a single resistor.
1/RT = 1/R1 + 1/R2 + 1/R3...
Posted: 02 May 2021 01:54
by Maximilian
Yes, the total amout of power will be divided between the two resistors.
So if the original resistor is 1/4th of a Watt and the two replacements are also 1/4th of a Watt, the replacements will be a lot cooler.
Make sure that the resistors have enough room between them so that they do not heat up each other.
Posted: 02 May 2021 19:13
by Steve
Thanks guys much appreciated :)
