Page 1 of 1
Simple ST2VGA adapter
Posted: 29 Apr 2021 21:35
by Methanoid
Was wondering differences between the IN STOCK ST2VGA and the UNAVAILABLE UbeSwitch
I can see the Ube
--adds trim pots for colour - are they needed?
--adds volume control - most monitors or speakers have this dont they?
--autodetection of resolution (in software) - no idea if this works, last time I looked at it, it was a WIP
can you change the jumper with ST switched on? ISTR it just resets for Hi or Lo/Med resolutions - is there a reason it doesnt have a slider rather than a jumper?
Re: Simple ST2VGA adapter
Posted: 29 Apr 2021 21:41
UBE info is here...
https://www.exxosforum.co.uk/forum/view ... t=161#p708
As to if you need a volume control and other features, really depends down to user preference.
Posted: 04 May 2021 12:16
by Methanoid
Thanks, I bought it and it arrived (quickly, thanks!)
Havent dug out my 15kHz monitor yet but plugged VGA into monitor. I got vertical bars which I have seen before on STs. I am pretty sure its NOT the adapter but there is some fix (as Ive had it before years ago).
Can you suggest fixes please?
- 20210504_111755.jpg (455.4 KiB) Viewed 3492 times
Posted: 04 May 2021 12:37
Methanoid wrote: 04 May 2021 12:16
This question comes up every couple of weeks, other than changing scaling on your monitor which may be causing vertical bands, or invest in a more modern motherboard like the H5. such faults are just inherent design faults in the original motherboards and are not really easily solvable.
Posted: 04 May 2021 13:01
by czietz
In almost all cases these bands are caused merely by incorrect monitor settings. Try the "auto" setting button. If that doesn't work, try adjusting the setting that might be called "clock" or "pitch" :
http://www.techmind.org/lcd/phasexplan.html
Posted: 04 May 2021 13:04
by Methanoid
czietz wrote: 04 May 2021 13:01
Thanks, thats the sort of thing I did a few years back to fix the issue... Will try
