1040 STE no sound....quest accepted
Posted: 12 Mar 2021 09:47
Dear all,
similar to many others I found this site when looking for more information on a problem I have with my lately purchased Atari 1040 STe.
As the title of this post tells you the Atari is all silent. I could now get rid of it and try getting another one but I see this as a quest.
It drives me mad to not know why is this also because everything else seems to work fine.
I've looked through the 208 topics in the HARDWARE ISSUES corner of this forum but related to my problem I could only find "TT no sound" and read into it. There it seems to me that the TT had a bit more problems rather than in my case where everything is working fine except for the audio output.
The TT's PS had good voltages and the LMC1992N had its 8.2v pin good. In my case it's a little bit different (no on-board speaker, no dip switches, no blown off board traces, etc.) and I'm not sure if this complicate things or simplifies them.
But lets have a look on the machine and what I could find until yet:
01
02
Sysinfo of the machine, 4MB Ram, Blitter on, DMA Sound available, cookie jar has some sound hardw.?
03
From exxos i bought the diagnose cartridge and got me the manual STE_Field_Diagnostics_v19.pdf.
03a
Unfortunately I had not all of the needed fixtures, no oscilloscope and not all hardware (high-res-screen, hdd).
03b
So I went through the tests as far as was able to (green = pass, red arrow = lack of fixture/hardware, red cross = fail)
In the audio test I should hear at least the PSG sound sweep from low to high frequency, which isn't hearable.
For the DMA Sound test I would need an oscilloscope, which I don't have but I tried some games....
03c
03d
About the games I loaded it is written that they definitely have DMA sound implemented (Xenon 2, Obsession, Dynabuster+)
But all silent still.
03e
After a bit of research in the web I came across this post and started measuring as advised...
YM2149F IC has its +5V.
LMC1992N IC has +0.3V ?!?!?
so I searched for the LM78L82ACZ transistor and...
03f
...found it
On the LM78L82ACZ I could measure +12V going in on the right side and the +0.3V leaving on the left side watching on the transistor like in the picture above.
03g
So I desoldered this thing and ordered a new one from Nikko Electronics. Soldered the new one in and....
Voila! ....same result as before, 12V in & 0.3V out.
Here I am standing now.
20a
What I truly not understand: The transistor seems to stand pretty much isolated from the rest of the wiring and seem to has only one job = getting 12V giving 8.2V further on.
I mean isn't it irrelevant if everything past that transistor is malfunctioning or is the behavior of this assembly part influenced like "I'll give you only 8.2V if you are asking for from behind".
Advice from the "TT no sound" topic....
1. Replace DACs.
-> Are they relevant to my problem as described?
-> When it comes to desoldering IC's I would clearly have to raise the white flag
2. Check if chips related to sound have 5V and clock.
-> Voltage I can check. With what type of equipment would I check clock? (but clock should be there because of field test 'timing' = pass?)
3. Also, check the power supply. One of the first things to go when my old PSU was on the blink was the sound.
-> On several places on the board I can find +12V and +5V so I think it's okay.
-> Bought another PSU which arrives in some days
4. I would check the ym chip outputs show something on key presses to see if there is at least a source signal...
-> The 1040 STe has no key-click right?
-> If it would have keyclick where could I find / activate this and after it's on especially how to measure this?
5. For troubleshooting get the schematic and trace the sound from the PSG to the output.
-> I 'think' I got all schematics available but have no "storyboard/plan of procedures" to trace whatever.
So that's all and a lot to my little riddle. I would be really thankful for any hints on that.
Yours sincerely
Raik
01
02
03
03a
03b
03c
03d
03e
03f
...found it
03g
20a
1. Replace DACs.
Yours sincerely
Raik
