I'm gonna be re-capping some Atari PSU's over the next few days and thought it might be a good opportunity to try and get before/after results like Exxos did in his PSU research. Could anyone recommend the basics to me like basic probe placements and settings to have the Oscilloscope on.
Ie; would you scope the voltage directly while it is powering an ST or using load resistors. Does it make a difference where you probe etc.
Cheers :)
Re: Practicing my Osc skills advice
Posted: 12 Feb 2021 22:49
by Steve
I've been watching EEvblog to make sure I don't make any silly mistakes. Been quite a few years since I was at college using oscilloscopes :)
Posted: 12 Feb 2021 23:19
I think dave did a review of our scope..
ah just screw around with it.. probe the 8Mhz clock and fiddle and learn what all the buttons do.. or just press AUTO and not bother like me :lol:
Posted: 13 Feb 2021 11:38
by Steve
Okay just hooked it up like this as shown in photo. Made sure to move away and isolate the 12v line with capton tape just to be extra safe. Having my probe on 10x does this reading show about 100mv of noise? Because it's about half a square of 20mv x10? Just learning how to read these again :)
Posted: 13 Feb 2021 12:06
Theres a setting in the scope to change to x10 probe somewhere.. so you dont have to translate voltages..
Posted: 13 Feb 2021 12:57
by Steve
Found it Chris :) cheers
As a reference, this is my SR-98 I use for testing. It is fully recapped already and shows very good regulation and about 50mv of noise:
Here is the first PSU I'm servicing today.. DSP 508a... holy smokes! It fluctuates massively and doesn't even output 5v. Fluctuates between 2.7v and 3.4v.. crazy :
Posted: 13 Feb 2021 13:29
by mst
Steve wrote: 13 Feb 2021 12:57
First one is very good, 50 mv on a 5 volts signal is more than ok!
Second one is completely bad, it appears that the self regulated switching rate of the PSU doesn´t work properly.
Posted: 13 Feb 2021 14:30
First image looks OK.. If you use reduce the time base, maybe 500ns you should see a sine wave which is the ripple...
Your second image looks like part of the ripple.. If you increase the time you may see it better...your on 200mv as well... Try 50 mv like your first image..
In the measure menu, you can show volts min and max on screen..
Posted: 13 Feb 2021 15:55
exxos wrote: 13 Feb 2021 12:06
Agreed, mine has a 10x switch on the probes, but if you forget to adjust the settings in the menus, it can really fool you. Most of the time I find 1x more than good enough on my scope.
Been caught out a couple of times too by accidentally knocking the switch to 10x and not noticing.
