Problems with my Atari 1040STf
Posted: 15 Oct 2020 02:02
Hi there!
A while ago, I tried fitting a 4mb upgrade to my Atari 1040STf
I soldered some bad connections on the shifter adapter from the upgrade, and my machine didn't output a valid monitor signal anymore.
The floppy led was also not lighting up.
I put the machine back to stock, but still nothing...
I tried doing the pin fix for the mmu socket (https://www.exxosforum.co.uk/forum/viewt ... hilit=plcc)
That didn't seem to work also, so I thought the shifter went bad due to my bad soldering.
Just now, I thought I might try that MMU socket pin fix again for some reason, and I'm glad I did because my machine is doing something again!
I turned on the machine, and I saw the TOS desktop, and I could use the mouse and everything, so I thought I fixed it.
But then, after about 20 seconds, the graphics started to get glitchy, and 10 bombs appeared.
I booted up the machine a few times now, and the Atari did what I just said most of the time, but another time, it booted into TOS, and it took about 2 full minutes until the graphics got glitchy and bombs appeared. (not sure it was 10 bombs every time)
After that, the screen went white, with 3 bombs.
Sometimes it just instantly boots to a white screen with bombs (also 10 I think), and another time it just booted to a white screen (when this happened, the floppy LED lit up again).
One of the times, the monitor didn't get a signal, and I also heard a high frequency noise coming from somewhere (couldn't hear whether it was coming from the motherboard or the monitor (but I think it came from the board, and it didn't sound like it should be doing that)
I did use a real Atari monochrome monitor today, and a new exxos PSU.
Last time (before it started working again) I used a vga adapter and an LCD screen (in monochrome mode) and a stock PSU.
The VGA adapter and LCD screen still work on my other Atari, same with the old PSU, so they're not broken or anything.
Don't think those things would have anything to do with the problem, since the original Atari monitor also didn't receive a signal before I fixed the MMU socket pins today, but I can try using the LCD again tomorrow if anyone needs to know if that setup also works again now, but I'd guess it would.
I'm glad I got my Atari a bit closer to fully working again today, but I still don't know what problems there still are...
I tried to explain everything as clear as possible, so I hope someone will know what's up!
(PS. If I need to take pictures or video of what's happening, just ask and I'll do it tomorrow!)
