Power supply takes out YM2149
Posted: 11 Oct 2020 11:02
Hi,
I have a US STFM with a dead power supply. I've been using a 12/5v power supply that is intended to be used with external hard disk drives and this has been working well, but I wanted to return the STFM back to a more original state. I ordered a used/tested power supply from an on-line vendor that specializes in Atari hardware for about $40. Today I installed this supply and upon flipping the power switch I heard a clicking sound coming from the direction of the power supply. A few seconds later smoke came from under the Atari disk drive. I quickly turned off power.
Upon disassembly, it turns out the magic smoke came from the YM2149 sound chip. There is now a nice hole in the top of the chip to help with cooling. I removed the now destroyed chip and installed a 40 pin socket along with a new YM2149 that I have on hand. Using the 12/5v hard drive power supply the machine once again boots up and appears no worse for the wear.
I then started to look at the "new" power supply, this time outside of the computer on the bench. After applying power to test output voltage a cap exploded in the low voltage DC side of the power supply. For sure a bad power supply.
Not sure exactly what voltage the power supply put out when first installed, but my guess is that some AC was present on the DC rails. I've contacted the vendor to see if there is something they might be willing to do, but my guess is that a used/tested supply is a buyer beware kind of situation.
I think I'm going to avoid vintage Atari power supplies as a drop in replacement and just use the supply from of the external hard disk drive. You can buy these hard disk supplies for $5 on ebay. I'll take the power brick apart an pull out the PCB. I can then mount this PCB on the Atari sub-frame. So, then I can keep the Atari power plug and switch which will keep the machine looking 100% original on the outside while using a more reliable modern power supply internally.
