Page 1 of 3
Isn't this the most frequently asked question?
Posted: 07 Oct 2020 03:14
by dnk777
Hi, this seems like something I should be interested in, as an user of both Atari STFM & STE, but I just spent half an hour trying and failing to find an information about what these boards are useful for... if they will it raise framerate in games..
I tried google, I tried going through this forum, I learned about BOM, firmware issues, cap values, and also about some war with some ridiculous "vampire team... but I still have no idea which ways would my Atari ST be more powerful with these boards, which I can't believe not being the most frequently asked question, but the FAQ thread doesn't answer it... it rather answers technical aspects about cap values and BOM, and not the most basic question about what these things are.
Then there is also the general "TerribleFire Accelerators" thread which says "The ethos of my project is to produce designs that are GPL for the Amiga and ST.", which is nice, but vague and doesn't answer my question.
The it lists some specs, which doesn't tell me much without further context.
Very confusing.
Re: Isn't this the most frequently asked question?
Posted: 07 Oct 2020 04:51
its a 50mhz cpu with fast ram.. It will run very fast anything you load into fast ram.. Not much else can be said really.
Posted: 07 Oct 2020 08:30
by tomster
+1 to what dnk777 said.
It is very confusing. I would at least have expected a short description on what the boards is good for in your shop. No offense.
Best
Tom
Posted: 07 Oct 2020 08:48
by terriblefire
I think the description is perfect. If you don’t know what it is then it’s not for you. Seriously! We do not want to deal with people who buy them then realise they are out of their depth soldering/flashing/debugging.
But in summary. All TF5xX cards are aimed at the Amiga 500 and are 680x0 cards with X relating to the amount of fastram. By happy accident these work on the STFM, H4 and Amiga 2000.
Posted: 07 Oct 2020 09:23
by stephen_usher
Indeed, it's a development board more than anything. Here's how I would describe it:
The TF536 is a prototype CPU replacement board for DIL 68000 processors specifically targeted at the Commodore Amiga A500 and now unofficially the Atari STF(M) and Mega computers. It has a 50 MHz 68030, 64MB (or now possibly 128MB) of fast RAM and a rudimentary IDE interface.
The board will, with the help of a suitable version of the operating system and utilities, speed up the base machine, the degree to which depends upon what the program is doing and whether it is able to run in "fast" memory or not. Many games have been demonstrated to run significantly faster.
The "firmware" for the device is in active development on both platforms and hence owners will be required to be able to update this from time to time.
Even if a user obtains a fully built board they will still need to have significant soldering and desoldering skills so as to replace the 68000 on the mother board with a socket. Atari machines will also require a ROM decoder board and at least TOS 2.06 as well.
This is not a board for novices. It is also not, as yet, fully debugged and some functions of the host system may not work correctly, e.g. the ACSI port on the Atari ST.
Does that help?
Posted: 07 Oct 2020 09:24
by tomster
@TF
I get your point but there are also folks out there who are not 'initiated' yet but take their chances because they like tinkering around. I definitely want to check this out and I won't complain if I fail due to my lack of expertise.
So it'd be good to know e.g. which boards/ST computers this boards is compatible to begin with. (H5 as well, I assume?)
Posted: 07 Oct 2020 09:32
by tomster
And thanks for the explanation, TF and stephen!
Posted: 07 Oct 2020 10:26
by stephen_usher
tomster wrote: 07 Oct 2020 09:24 @TF
That's still being worked out by trial and error.
Posted: 07 Oct 2020 10:31
by terriblefire
stephen_usher wrote: 07 Oct 2020 10:26 That's still being worked out by trial and error.
Exactly. As i've said over and over.. this isnt and was never intended to be a product. Everyone's mileage varies.
Posted: 07 Oct 2020 10:46
by JezC
No-one has an H5 to test with...but it does "work" on an H4 (quite a few of us have that running in some form with various configurations) so it would be expected to work on the H5 as well (but not guaranteed!).
If you're wanting it for a specific purpose then it may be worth waiting a bit longer (and maybe let people know what your ultimate goal is) but if you're happy to get one just for experimentation purposes with no guarantees, then it's certainly worth considering.
As to whether your ST will survive any work required to allow the TF to be fitted (e.g. socketing the processor, any/all of the mandatory fixes posted elsewhere)... well, that's anybody's guess!
Also, bear in mind that it's really been most widely used with EmuTOS on the ST (though there are some success stories with TOS 2.06 as well) - and pretty much all of those solutions require the additional ROM decode circuitry to support the 256k ROMs.
The big exception to that which I'm aware of is the clever workaround from @agranlund which replaces the 192k ROMs with an EmuTOS boot image (192k still) which then allows EmuTOS to load from floppy or IDE into memory.
If you can, then certainly consider an H4 (@PhilC is possibly considering selling one of his) or an H5 as the TF536 is a plug-in option for one of these board (but still needs the 256k ROM decode adding) - and potentially needs a lot less work than any STM/STF/STFM/Mega board.
It'd be interesting to know what you decide & any specific applications you are considering.
