Floppy Stops working with megafile connected.
Posted: 29 Jul 2020 09:18
coming over from this topic https://www.exxosforum.co.uk/forum/view ... =20#p45412
Hi everyone. I have everything set up and all powers on.
But i have an issue. If the megafile is turned on the floppy wont work and errors with "insert disk" and doesnt read anything, but if the mega file is off, the floppy works fine. There's a red switch on the board, they are all flipped to the top.
I have a copy of the disk with all the utilities and proper drivers on it. Tried AHDI and ICD. which i cant use because the floppy dont wanna work.
My ST has 4mb of ram, so its not low on memory.
The Atari sees the drive as it lists "2" when it starts
The floppy drive does not autoboot the floppy but it makes like three clicks as it tries to read, it'll do the same when in GEM too.
But like i said the floppy drive stops reading anything. "insert disk" Either on A: or B:. Doesn't even read when booting.
Turn off the mega file, drive works again without any problem.
I have TOS 1.04 with the exxos adapter.
Display is through an UBE ST to VGA.
i want to get the megafile working.
There really isn't all that much i can find about what programs to use to set up the atari st hard drive with.
