Page 1 of 4
TF536 IDE speed
Posted: 30 Jun 2020 12:36
by kulamario
Welcome
I done my 5 boards but I think is something wrong speed in SysInfo show me 600-700kb/s when i write in shell
CPU Fastrom i have up to 2mb/s
Another think games like Doom and Nemac start freeze after some time
I check this on CF Card and SD Card
Procesor from Ebay 030 50mhz
System 3.1
and as well I check this on 3.1.4 on this one max transfer what I get was 650kb/s
Please any advice with this
Re: TF536 IDE speed
Posted: 30 Jun 2020 12:43
by PaulJ_2.0
Re: TF536 IDE speed
Posted: 30 Jun 2020 12:47
by alenppc
kulamario wrote: 30 Jun 2020 12:36 Welcome
Sysinfo is awfully bad at this. For more accurate results you should use a specific disk transfer benchmarking software, such as diskspeed. But as you've confirmed, FASTROM improves transfer.
And there is your problem. It's most likely a fake/reprinted CPU. Want to find a sure fire way to make it crash? Download memcheck12.lha from aminet and run it on fast ram. It will make a fake/reprinted CPU crash at some point.
Re: TF536 IDE speed
Posted: 30 Jun 2020 13:08
by terriblefire
This is well known and well documented. This is what you get. Its because without fastrom the scsi driver is running out of slow rom.
On CD32 you can get 1.4Mb/s without fastrom and 2-4Mb/s with it.
Re: TF536 IDE speed
Posted: 30 Jun 2020 13:13
by kulamario
Problem sort thanks lads
Now must find what is going on with this two games
When I left super frog for whole night run without problem same frontier working perfect but Doom and Nemac no want
Re: TF536 IDE speed
Posted: 01 Jul 2020 10:12
by matt020
kulamario wrote: 30 Jun 2020 13:13
What was the solution??
Re: TF536 IDE speed
Posted: 01 Jul 2020 10:45
by terriblefire
matt020 wrote: 01 Jul 2020 10:12 What was the solution??
There was never a problem.
Re: TF536 IDE speed
Posted: 01 Jul 2020 17:28
by richx
kulamario wrote: 30 Jun 2020 13:13 When I left super frog for whole night run without problem same frontier working perfect but Doom and Nemac no want
Post a picture of your 030. As mentioned, you might have a fake "50Mhz". I believe the TF will clock down CPU when accessing chip/slow RAM, which is probably majority of what Super Frog does, whereas Doom would be more heavy on SDRAM running CPU at full clock speed.
Re: TF536 IDE speed
Posted: 01 Jul 2020 18:20
by Homer79
Thanks Ill try this program with my TF536 and see what it does
[/quote]
[/quote]
Re: TF536 IDE speed
Posted: 01 Jul 2020 18:36
by kulamario
Bought from this seller www.ebay.co.uk/itm/143326528869
