Page 1 of 1
Atari SC1435 different HOT/PSreg
Posted: 23 Jun 2020 18:13
by sandord
Haven't been active on this forum for more than a year... I miss this place and all of you! Anyway, here goes.
I'm recapping an Atari SC1435 colour monitor (basically the same as the Commodore 1084S/Philips CM11342) and all of the three service manuals show BUT11AF for part 7432 (PS power regulator) and BU508AF for part 7512 (HOT).
But, what I found in this particular unit was a D1577 for part 7432 and a C3795B for part 7512.
What caught my eye was a significant amount of raisin-like residue at the soldering joints. That makes me believe that someone replaced them before. But I can't be really sure. Maybe this unit is a revision of some sorts that doesn't match my service manual.
Since the specs of the mismatching parts are different, I'm not sure if I can safely put replacement parts in the unit as suggested by the service manual.
BUT11AF: Vcbo 1000V, Vceo 450V, Vebo 9V, Lc 5A, Lb 2A
D1577: Vcbo 1500V, Vceo 600V, Vebo 5V, Lc 3A, Lb 2A
BUT508AF: Vcbo 1500V, Vceo 700V, Vebo 10V, Lc 8A, Lb ?A
C3795B: Vcbo 1300V, Vceo 600V, Vebo 8V, Lc 6A, Lb 3A
I don't know enough about electronics to assess whether this was a safe replacement or that this units had different parts from the get-go.
So basically my question is: is it safe to replace 7432 and 7512 with parts that meet the original specs as listed in the service manual?
Re: Atari SC1435 different HOT/PSreg
Posted: 23 Jun 2020 18:16
by Tomswork
Please be careful the parts your are working with are horizontal output transistors
NPN Si Transistor, HV Horizontal Output - NTE2300
Tom
Posted: 23 Jun 2020 18:17
by derkom
sandord wrote: 23 Jun 2020 18:13
When I serviced a dead 1435 I picked up last year, the HOT (which appeared to be original) was a D1577. I replaced it with a BU508AFI and everything is working fine.
Posted: 23 Jun 2020 18:21
by sandord
Tomswork wrote: 23 Jun 2020 18:16
Tom
Well, I have a bunch of BUT11AF and BU508AF parts in my possession so I have no problem meeting the service manual specs. It's just that I'm very curious why there are different parts in this unit. I could simply ignore that but I don't want to blow it up.
Hmm, I'm just starting to realise that if I verify that the other parts are up-to spec and there are no modifications, the parts from the manual SHOULD work...
Posted: 23 Jun 2020 18:22
by sandord
derkom wrote: 23 Jun 2020 18:17
Well, that's very useful information. Thanks! Apparently there is some headroom to the specs in this case.
Posted: 23 Jun 2020 18:24
by Tomswork
It could have been serviced in the past or was made on a Friday
The high spec parts should work fine
Tom
Posted: 12 Apr 2024 19:32
by sviru
Will hijack the thread. My 1435 is not working. High pitch sound. I guess flyback is gone. But. My question is about HOT. Mine is D1577.
How to check HOT? When I measure B C E to Ground there is a short. I thought that D1577 is shorted. Desoldered and out of the board D1577 - no short.
The board still has short to gnd from either B C E solder points. \
Is this a "normal" thing when flyback is gone - or something else died? Thanks for ideas.
Posted: 12 Apr 2024 19:40
I haven't touched monitor for over 20 years now, but if I remember rightly, the main switching transistor will likely measure short-circuit because it is across the coils of the flyback transformer anyway.
But considering you have a high-pitched whine, I would suspect that it is actually switching. But of course, it will be better to remove the main driver transistor and check it anyway.
Posted: 16 Apr 2024 12:25
by sviru
exxos wrote: 12 Apr 2024 19:40
Desoldered the FLYBACK and there is an internal short inside it. Transistor measures fine.
Since flyback is on its way to me I will replace FLYBACK tomorrow. Fingers crossed!
