MegaST4 Stability running cubase
Posted: 17 May 2020 10:46
Hi all,
I aquired a Mega ST4 a month or so back. It was very unstable so I've used the exxos kit of parts to rebuild the PSU and shows the correct voltages. This has made a massive difference to it, in that it behaves a lot better.
I'm trying to run cubase 3.1, with a Unitor plugged into the cartridge port. I'm finding that it seems to work fine for a while, then it will start give 'internal error' popups. If i then restart cubase it will then complain of 'no key' for cubase.
So something is still amiss hardware wise. I do have some extra bits to fit, like the buffer and the booster, but i dont want to go anywhere near that until i've figured the instability issue.
So, seasoned atariists, where would you look to think about troubleshooting this? Is it possible it's ram related, or is this likely to be some form of power issue on the motherboard itself
Thanks in advance for any encouragement or support!
Rich
Rich
