Page 1 of 1
RAM Upgrade for a 520ST
Posted: 03 May 2020 03:56
by Colleton
I have a nice 520ST with TOS 1.04 that I'd like to upgrade the memory on.
I plan on using the Exxos ST/F/M / MEGA ST-RAM 4MB UPGRADE [0035] upgrade, but am lost as to which of the 3 cables I should get.
I'm attaching a pic of my motherboard so that layout can be seen. Any advice would be appreciated. Thanks!
- 520st_mobo_sm.jpg (107.87 KiB) Viewed 6436 times
!Message from: Moderator
@Colleton, we have placed your attachments in-line so they display correctly in your post. Here's the
how-to guide.
Re: RAM Upgrade for a 520ST
Posted: 03 May 2020 09:14
Locate the MMU, which as I recall is the furthest left PLCC socket on your mainboard, and measure the distance to the Shifter which is in the tin can on the right hand side, then use that measurement to judge the cable size you need, without the cable being under tension when installed.
Posted: 03 May 2020 09:35
Posted: 03 May 2020 09:56
As it happens, I will probably be upgrading mine later today.
I have a 30cm cable as it was originally intended for one of my Megas, which I got fixed, so I can confirm if it's longer than you need.
I'd suspect as @exxos says, 20cm is going to be enough.
Posted: 03 May 2020 10:10
Just opened mine up, 20 cm it is.
Posted: 03 May 2020 11:33
This is it fitted to mine with a 30cm cable, once again confirming the 20cm option.
I did remember the MMU position incorrectly though, it's the chip here you can see the MMU adaptor on top of (Unsurprisingly!), the other, towards the left, being the GLUE.
- Fitted.jpg (145.66 KiB) Viewed 6393 times
Posted: 03 May 2020 13:26
by Colleton
Awesome, great info. Thanks everyone!
Posted: 03 May 2020 15:47
Colleton wrote: 03 May 2020 13:26
No problem and good luck.
Posted: 18 May 2020 04:33
by Colleton
Received the 4MB MMU ram upgrade this weekend, and got it installed in my 520ST this afternoon. Everything went very smoothly, no problems at all.
Also installed a blitter in my STFM. It was a busy day today.
- 4mb_ram.jpg (115.57 KiB) Viewed 6305 times
how-to guide.
Posted: 18 May 2020 09:11
Colleton wrote: 18 May 2020 04:33
Good job sir, it's a very nice upgrade.
