A couple of years ago, a friend of mine who processes a lot of surplus hardware (and feeds various oddities my direction) gave me a
Mindset M1001, an 80186 nominally PC compatible computer that I understand was designed by some of the same engineers who built the Atari 400/800. He had not powered it on, and the box ended up in the attic.
- IMG_20200513_200129.jpg (45.09 KiB) Viewed 5794 times
A couple of days ago, I finally pulled it back out, opened it up and discovered the PSU is shot, transformer dead. So I pulled out a
Meanwell RD-50A, built a little inverter board to produce the -12V rail the Mindset wants, and connected it up via the original power connector from the dead PSU.
- IMG_20200513_140910.jpg (94.33 KiB) Viewed 5794 times
Plugged it in, flipped the power switch on the keyboard, heard the power relay click inside the main unit, and then .... Hey what's that smell? Oh no, the magic smoke has been released from the keyboard! :fire: Quickly pulled the plug and went to investigate. Inside the keyboard I found this:
- IMG_20200510_181614.jpg (111.43 KiB) Viewed 5794 times
Eek! Fortunately I was able to determine from others' photographs that these used to be 51 Ω resistors, so I could replace them, but no point in doing that without finding the fault. The resistors in the keyboard are just the weakest link, and likely the old PSU
used to be the weakest link, and that is why it's dead.
Fortunately, since this is just the power relay circuit, there wasn't much to investigate, and it didn't take me too long to find a 1N4148 right next to the power relay on the main board that was showing 1 Ω resistance in both directions, and which would create a 12V dead short through those resistors when the relay was turned on. I had some extra 1N4148s left over from the H4 project, so that was a quick replacement, and despite the PCB in the keyboard being somewhat burnt, it was still electrically fine, so the 51 Ω resistors there were a simple replacement as well.
Plug it in again, flip the switch again, ...
- IMG_20200513_160122.jpg (108.15 KiB) Viewed 5794 times
:excited:
It works! It came with a few floppies and seems to boot MS-DOS 2.0 just fine. So now I will find some space somewhere to finish setting it up.
