Page 1 of 9
Module ESP8266 without TF on Amiga
Posted: 12 Apr 2020 18:59
by kulamario
Welcome
Motivated by the owners of TF330 have the ability to use the internet via WiFi
I made a schematic and board for ESP8266 without using TF
As I understand the system must be connected to serial port not to parallel
I also read that the port in Amiga has only 20mA so it is not suitable for powering the system
therefore a USB port is added
Unfortunately the system is not checked due to the lack of parts in the house
Re: Module ESP8266 without TF on Amiga
Posted: 13 Apr 2020 10:55
by terriblefire
You can buy these off ebay already i think.
https://www.ebay.co.uk/p/1289323679?iid=293171063571
Posted: 13 Apr 2020 10:57
by kulamario
This one is Bluetooth no WiFi
Posted: 13 Apr 2020 11:03
by terriblefire
kulamario wrote: 13 Apr 2020 10:57 This one is Bluetooth no WiFi
Oh. Ok. well personally I would use DB9 to reduce the PCB size. Then use a gender changer. I'd also consider not bothering putting the chip on it but make an ESP header. That way when extra super duper versions come out your wont need to respin your board.
If the 3 pin header is for programming vs usage then you may want to find a way to power cycle it if you havent thought of that already.
EDIT: Also you can get power from the floppy connector...
Posted: 13 Apr 2020 11:12
by terriblefire
DB9 + Header is also way easier to assemble and give the board wider appeal.
Consider a 5V 0.1" header on there for anyone who doesnt want to bother with USB power.
Posted: 13 Apr 2020 11:59
by kulamario
What I wanted to achieve is a uniform module that we connect to the amiga when I used DB9 we would have to use adapters
With the addition of pin header to the power supply no problem can be added
Posted: 15 Apr 2020 15:20
by kulamario
Yesterday i got adapter
I try to connect everything like on the picture
I flash ESP8266 witch both files https://github.com/terriblefire/terribl ... er/esp8266
OFFSET i setup like names files .bin
I dnt have to setup ESP8266 module via AT commands?Just flash firmware?
For flashing i use Nodemcu on Windows
For connect Internet i use MiamiDX
But dnt know how to install drivers Icslip-sana2.lha on Amiga and how to run this install_script
Please help me
ESP8266 to Amiga.png (384.7 KiB) Viewed 7172 times
Posted: 15 Apr 2020 15:24
by terriblefire
kulamario wrote: 15 Apr 2020 15:20 Yesterday i got adapter
Please help me
My script is for roadshow only.
For anything else you need to do this loooooong process.
https://hackaday.com/2019/07/03/amiga-i ... n-esp8266/
Posted: 15 Apr 2020 16:29
by kulamario
so best way is install Roadshow and then start test
Posted: 15 Apr 2020 16:45
by terriblefire
kulamario wrote: 15 Apr 2020 16:29 so best way is install Roadshow and then start test
To prove your hardware is working i would install roadshow and then run my script. Also Roadshow uses less RAM (i think) than most.
