Help - Issue with Exxos 4MB RAM UPGRADE
Posted: 20 Mar 2020 05:48
Few months ago I purchased the 4MB MMU TYPE RAM UPGRADE from Exxos site, and I never was able to get it running.
I first tried to install it into 520STM (pictured) C070243 Rev. H. I consider myself pretty good with soldering iron and putting the shifter adapted together was easy. I desoldered one end of R133 and R134 and connected it to 5V.
Before powering on the machine, I double-cheked with voltmeter in continuity mode that I don't have any shorts and everything checked ok. So, I powered on the machine and all I saw was bunch of color bars.
Since my TOS was v1.0, someone suggested here on the forum for one of the posts to upgrade the TOS to v1.4. I did that and color bars turned into black screen with white bars and it still didn't work.
Next I added pins for the 1mb/4mb jumper and tried in the 1mb mode, but that didn't help
There was another post here where it was suggested to remove the ram chips. (viewtopic.php?f=29&t=1549) I tried that as well and still got same results. Btw, if I removed the Ram Upgrade boards, the machine ran as ussual.
Since my C070243 Rev. H board looked a little different than Spiny's C070243 Rev. H used in http://www.spiny.org/atari/photos/exxos_4meg_stm/ (Notice how on my board the following were populated C107,C127,C108,C121, and unmarked capacitor next to U45) and the user from the link above had the same issue as me, I thought that it might be that this revision was not supported. So, I got another spare 520STM with C070243 Rev. B and Ram Upgrade produced the same results. At this point, I thought that maybe this upgrade does not work with NTSC machines, I also aquired an 1040STF C103175 Rev.1. It had a soldered MMU which I removed with the heatgun and added the socket and small adapter for the RAM MMU adapter board, and still got the same result.
I like finding faults and fixing things myself, but at this point I am out of ideas without schematic. I'm convinced that the either board(s) or ram chips are faulty. I find it very unlikely that I maybe didn't solder something right since it was just the socket and the pins. Everything else came pre-assembled. By now I checked numerous times for shorts on all the pins on all points (socket, cable header, ram chips, pins on the shifter adapter and on the MMU adapter) and everything seems ok.
Is there anything else I can do to check the boards or the chips?
