Page 1 of 5
diagrom showing 0 fastmem on new board
Posted: 17 Nov 2019 20:47
by oggie
So I just finished soldering up my 2nd board and programmed the CPLDs. When I boot into diagram, it sees the 68030, but it's showing 0 for fastmem.
I double checked the solder joints and i don't see anything wrong.
Is there anything I can check?
Re: diagrom showing 0 fastmem on new board
Posted: 17 Nov 2019 20:57
by PaulJ_2.0
Use a fluffy type microfibre cloth to lightly clean the ram and ram cpld. The cloth will snag on an unsoldered leg without pulling it out of shape.
Works a treat :D
Posted: 20 Nov 2019 17:15
by oggie
So I tried your trick and didn't find any unsoldered legs.
I have an lcd microscope that I got from aliexpress and it works well enough to see the solder joints. I don't see any bad joints. I wonder if I have a bad board, but I'm not sure what to check to see if I have a bad one.
Posted: 20 Nov 2019 17:26
by terriblefire
Did you use DiagROM to try scanning 0x200000 to 0x600000 manually?
Posted: 20 Nov 2019 17:44
by oggie
No! That's the knowledge that I'm lacking. I will try that.
Thanks
Posted: 20 Nov 2019 22:19
by terriblefire
It should probably show you which bank is dead.
Posted: 23 Nov 2019 23:52
by oggie
https://photos.app.goo.gl/9XJWLaSjkjjgFCnC6
So I finally got around to testing this in diagrom. I think I picked the correct start/end address from the memory test.
So it looks like they're all bad? I've checked the solder joints over and over again and they look fine.
Posted: 24 Nov 2019 00:26
by terriblefire
something is wrong. Either chip select lines or address lines to the RAM CPLD.
Try running autoconfig.. if diagrom detects a card rom then the issue is maybe the data path rather than address path.
Posted: 25 Nov 2019 00:26
by oggie
ok. I ran autoconfig and got this :
https://photos.app.goo.gl/akyREk8uXiCKHf3C8
So based on your statement, that means it's the address path? the address path from the cpld to the ram chips?
I checked continuity from the cpld to the ram chips and they all seem to be connected.
Posted: 25 Nov 2019 06:18
by arkadiusz.makarenko
oggie wrote: 25 Nov 2019 00:26
Did you get parts from good sources?
