Bit of an odd IDE problem?
Posted: 17 May 2019 15:59
Hi guys,
First of all I just wanna thank you guys and Stephen in particular. It's been wonderful working with this stuff. My intention was to start a thread documenting my build, but I've ran into a small issue that I think is worth asking about. I realise the 530 is now somewhat depreciated, but since I already had the unused parts from last year I thought i'd build it up anyway. After sorting out the usual poor solder joint issues etc I got the board up and running without any issues.
The problem is IDE. I am using an IDE-SDCARD board, which may well be the issue. For small(ish) files I can move things over from one drive to another just fine, but for anything bigger than about 50-100k, the system often freezes. This is either in the shell or in dopus. I figured this was an OS/maxtransfer issue, but i've tried different filesystems and different sized cards. If I use UAE to populate the SD card, then I can run large-file programs (such as games) fine using the 530. It is only the writes that are the problem.
Crucially, at random times the copy will complete. Then on the next attempt the progress bar will freeze.
I'm running an EC40C at 50MHz without an FPU. I'm on the second to last firmware, but have also run the latest firmware with no real difference.
Right so everything with this card is for the most part fantastic. I've run both systest and MBRTest-2 overnight without a hitch, and had the frontier intro looping for hours again without a hitch.
Now I can live with this, obviously - I can just do my larger file transfers in UAE and move the SD card over, but ideally i'd like to iron out the bug.
My question is this - how to proceed next? Could running the EC40C (which to be honest is, i think, a re-screened EC33C) at 50Mhz be causing the intermittent problem? What about running without the FPU? Would I have such an otherwise rock solid system if that were the case? Finally I imagine this may well be a badly behaving IDE2SD. Could someone recommend either a CF2IDE or SD2IDE that they have found to work with the 530?
To test I have access to a 200MHz scope and a basic microscope, though to be fair if it was a solder bridge or something I don't think it would be working at all.
Sorry for the long post, and again thanks so much for giving to the community in this way!
Cheers,
John
Cheers,
John
