Page 1 of 3
Eiffel 3 Conversion of PS/2 sockets to USB Sockets
Posted: 29 Mar 2019 11:41
by Icky
Just another project to add to my never ending list of projects
viewtopic.php?f=18&t=1718
The Eiffel 3 is a great add on to the Atari ST if you are wanting to connect a PC PS/2 style keyboard to the ST.
- IMG_3689.jpg (72.91 KiB) Viewed 6208 times
Eiffel 3 site -
http://didierm.pagesperso-orange.fr/eiffel-e.htm
I didn't have any PS/2 keyboards knocking around at home but there are USB to PS/2 adaptors available to use USB keyboards and mouse.
They work fine but they look cumbersome connected to the Eiffel 3 - seems to mess with my OCD for neatness.
So I am going to remove the mouse and keyboard PS/2 sockets and replace with USB ones.
Below is the pin out and connections required to get this to work. Unfortunately it's not a drop in de-solder / re-solder job even though the pins marry up.
EDIT: This the correct pin to pin photo
- IMG_3690 (2).jpg (174.19 KiB) Viewed 6163 times
So a bit of hackery is needed :)
Re: Eiffel 3 Conversion of PS/2 sockets to USB Sockets
Posted: 29 Mar 2019 12:46
Icky wrote: 29 Mar 2019 11:41
I'm beginning to think that the amount of time available to do projects, is inversely proportional to the number of projects on the list!!
Posted: 29 Mar 2019 12:52
rubber_jonnie wrote: 29 Mar 2019 12:46
Welcome to my world ;) This is why I have stopped doing machine repairs and stopped doing a lot of kits over the past year.
Posted: 29 Mar 2019 13:05
by Icky
exxos wrote: 29 Mar 2019 12:52
I think the biggest problem is Idea = Project. That equation is the biggest issue in my book.
Posted: 29 Mar 2019 13:07
Icky wrote: 29 Mar 2019 13:05
I've got it!!
We all need to stop having ideas for a bit!
Posted: 29 Mar 2019 13:10
by Icky
Well I have had a first thought on this.
USB socket underneath is the simplest, would fit and you can patch the clock line over as that pin is NC. However its underneath and my neatness niggling voice in the back of my head is still there.
The Mouse socket became a bit of a stubborn socket hence the marks from ending up clipping the thing off.
- IMG_3691.jpg (88.05 KiB) Viewed 6186 times
by Icky
rubber_jonnie wrote: 29 Mar 2019 13:07
I've got it!!
You failed there RJ as that was an idea :)
Posted: 29 Mar 2019 14:03
Icky wrote: 29 Mar 2019 13:10
I've got it!!
:dizzy:
Posted: 29 Mar 2019 14:20
by PaulJ
I've got it!!
Ya know RJ, there's a printed case for the EIFFEL 3. You need to change it to support usb connectors. Just pretend its not an idea. ;) ;)
- case.jpg (32.3 KiB) Viewed 6177 times
Posted: 29 Mar 2019 14:31
STOP.HAVING.IDEAS
