Page 1 of 1
long button drive reading issues
Posted: 27 Aug 2017 23:08
by Gunstick
Hi
my long button internal drive is broken. It spins up and moves the head, but does not read the disk.
Is there a chance I could repair it myself?
Or shall I send it to you?
Or just buy a new one from you? And send the old in, in case you want to try to salvage it?
Georges
Re: long button drive reading issues
Posted: 27 Aug 2017 23:15
Gunstick wrote: 27 Aug 2017 23:08
Hi
Georges
Some things to bare in mind here.. They are mostly belt driven, if so it will need a new belt. Also clean the heads. A lot of long button drives were single sided so it may not read double sided disks anyway.
Posted: 27 Aug 2017 23:24
by Gunstick
I tested if the disk is rotating:
Insert disk, make the drive rotate.
Remove disk, rotate the floppy a little bit.
Insert the floppy again.
Make the drive rotate. There should be a "schllllick" sound of the notch slipping into the floppy.
I heard the sound: yes the floppy rotates.
Why I didn't just watch the motor? This drive is fully encased in a metal shield. So the audio method was easier than to dismantle it.
Unfortunately I have no head-cleaning floppy disk.
Posted: 27 Aug 2017 23:29
Are you sure its not just the motor you can hear running ? Belt slipping can also still spin the disk. You need to open the drive and takes some images.
You can see how I cleaned the heads in this topic..
https://www.exxosforum.co.uk/forum/viewt ... ?f=17&t=96
