Page 1 of 2
Testing the blitter
Posted: 22 Oct 2018 10:56
Long story short, it didn't work. :(
I tested the blitter in my STFM, and it works. In the STF I just get a totally black screen. I took the blitter out and reconnected the jumpers, and the machine still works fine. So no damage to be happening anywhere to the blitter or glue. I retested the blitter in my STFM and it still works..
So we have another mystery to solve..
I will start checking, I got really confused with all the BG IO stuff.. So I will start checking it all again, if anyone else can check it all out it will of course help...
Re: Testing the blitter
Posted: 22 Oct 2018 11:28
I cannot find anything wrong the diagram currently... I will keep checking..
There is BGO pin 45 of the GLUE where it is not connected to anything.. But I cannot see anywhere it goes currently...
Nowhere it seems... Checked on a few diagrams..
Posted: 22 Oct 2018 13:48
I cannot see anything wrong anywhere.. I have used the MEGA ST4 diagram to get the connections as it seems there are no jumper links in the mix on that machine.. Tracing that with my diagram both look the same to me..
:shrug: :shrug:
Posted: 22 Oct 2018 13:55
by PhilC
I did get the black screen when I put it in mine, it could be that I was just unlucky with the GLUE?
Posted: 22 Oct 2018 13:57
Forgottenmyname wrote: 22 Oct 2018 13:55
Maybe..
Nothing got damaged on my machine...yet...
Posted: 22 Oct 2018 14:56
by PaulJ
Guess I'll solder the socket in and give it a try. Think I'll start it with the test cart and a serial connection in case the screen is froozen. Could you tell if the processor was running?
Posted: 22 Oct 2018 15:05
PaulJ wrote: 22 Oct 2018 14:56
I've not scoped out anything yet, so don't know what is running or not... I'm checking the diagram over and over and now looking into the pull ups to see if they are to low in value or something...
Posted: 22 Oct 2018 15:10
:lolbig: :blonde:
OK running now :mrgreen:
- IMG_3343.JPG (111.6 KiB) Viewed 8823 times
Need to check these figures are actually correct next... We don't actually have a STFM benchmark with blitter in the benchmark section :roll:
Posted: 22 Oct 2018 15:28
by PaulJ
exxos wrote: 22 Oct 2018 15:10
:lolbig: :blonde:
I've been homing out lines other than address and data... all look good so far. What was the issue you had? Something I need to change?
Posted: 22 Oct 2018 15:32
PaulJ wrote: 22 Oct 2018 15:28
I un-soldered the wrong jumpers :)
