Page 1 of 1
Recapping Falcon PSU - My rectifier is different
Posted: 19 Sep 2018 10:39
by derkom
I'm in the process of recapping a Falcon PSU with exxos' kit (hoping to tame a ~300 mV ripple on the +12V rail) and after replacing all the caps, I've noticed that my rectifier doesn't look anything like the one in the photo on exxos' PSU page, and also there's a resistor missing from right next to it (R4). (I imagine it's simply not supposed to be there, and this is just a slightly different revision of the PSU. I am also missing R18 in the upper right.)
I am reasonably comfortable with electronics, but not nearly the level of a lot of you guys, so I figured I'd better ask here before continuing. Does anyone recognise this revision of the Falcon PSU, and am I good to continue here and replace the rectifier with the new one from exxos' kit?
Thanks!
Re: Recapping Falcon PSU - My rectifier is different
Posted: 19 Sep 2018 11:39
by kodak80
The bridge rectifier is the original square one and is correct. The one Exxos supplies is slightly different but has 4 legs so you need to make sure you align the positive and negative legs:
R4 and R18 was missing from my Falcon PSU and they look the same. Recap worked fine.
Posted: 19 Sep 2018 12:08
by derkom
kodak80 wrote: 19 Sep 2018 11:39 The bridge rectifier is the original square one and is correct. The one Exxos supplies is slightly different but has 4 legs so you need to make sure you align the positive and negative legs:
Yep, no worries on the legs. Thanks for filling me on the other details. I shall continue the project. :)
Posted: 19 Sep 2018 12:13
by derkom
Oh silly me. If I'd just looked at the beginning of the Falcon section on the PSU page, I would have seen a picture that matches mine. Good job, me. :oops:
Posted: 19 Sep 2018 12:20
The differences on the resistor are 110V vs 240V configs.. some better images in this section.
https://www.exxosforum.co.uk/forum/viewforum.php?f=59
Posted: 19 Sep 2018 12:54
by derkom
...and it's done.
+12V ripple before...
...and after...
50 mV/div in both cases.
:dualthumbup:
Posted: 19 Sep 2018 13:20
:bravo: :goodpost:
Posted: 19 Sep 2018 14:45
by Atarian Computing
derkom wrote: 19 Sep 2018 12:54 ...and it's done.
:dualthumbup:
Cool, so from 250mVpp to 100mVpp? What kind of load are you running here?
Posted: 19 Sep 2018 17:24
by derkom
Atarian Computing wrote: 19 Sep 2018 14:45 Cool, so from 250mVpp to 100mVpp? What kind of load are you running here?
Both times just using the load resistors supplied by exxos. :) "5V uses 2.2R (loads 5V rail with 2.2amps) and 12V uses 10R (loads 12V rail with 1.2amps)"
