Page 1 of 2
WANTED - Pico PSU
Posted: 25 Aug 2018 23:50
by marss
Can a Pico-PSU power a CT060+CTPCI+HDD+DiskDrive?
Thanks
Re: WANTED - Pico PSU
Posted: 26 Aug 2018 02:54
by Steve
Umm have you tried eBay?
Posted: 26 Aug 2018 08:47
by marss
I would like to buy from someone of this site, and, if unsuccessful, it will be Ebay.
Posted: 26 Aug 2018 09:11
I still have the ones I tested on my PSU page...
http://www.exxosforum.co.uk/atari/last/pico/index.htm
Posted: 26 Aug 2018 09:31
by marss
if yours can power on all my device (CT060+CTPCI+HDD+DiskDrive)... I'm a buyer. Plese PM your price ;)
Posted: 26 Aug 2018 09:52
marss wrote: 26 Aug 2018 09:31 if yours can power on all my device (CT060+CTPCI+HDD+DiskDrive)... I'm a buyer. Plese PM your price ;)
I don't know it they will power all that or not.. I never had good results with them. I really would avoid picos if possible. You may have to ask around other forums to see what people are using.
Posted: 26 Aug 2018 09:55
by marss
thanks
Posted: 26 Aug 2018 10:38
Be aware that if you buy from eBay you probably won't get a genuine Pico PSU.
You may buying a cheap Chinese copy, and whilst you will get it cheaper, that could buy you a device that is unreliable and might even kill your machine.
A genuine 160 watt Pico PSU will cost you €45, not the €18 you'll find them for on eBay, that cost reduction can come at a price.
I'd suggest if you want to go down that route, you should really consider calculating the power needed before buying to avoid disappointment.
Posted: 26 Aug 2018 15:09
by marss
@rubberjohnny... thanks for the advice
maybe a model you would suggest?
Posted: 26 Aug 2018 15:34
by Atarian Computing
Get a wide-input model like this: http://www.mini-box.com/PicoPSU-120-WI- ... wer-supply
It will take an input of 12-25V instead of just 12V. This usually results in a cleaner output. Also, it allows you to use the huge selection of 19V laptop chargers with it. 120W should be enough for your needs.
