I gated BUS ERROR but did not change anything.
I disabled the ROM enable (so doesn't run ROM from TTram) , let it get to TTram test, then ran my original ROM to TTram copy code (I removed the ROM copy code so it only verifies) and ...
- IMG_4601.JPG (37.79 KiB) Viewed 989 times
So the ROM shadow in TTram doesn't get corrupted.. its something else going on...
Theres only really the ROM shadow logic which is simple, and its ran overnight.. So its not like its unstable. But I can't figure out how it gets from testing TTram to crashing a few seconds later..
Oddly one of my latest ST536 boards doesn't run with the new firmware, it shows TTram corruption.. So that could likely be a clue..
It passes TTram test with fast slew.. I was using slow before..
The latested board (dual regulators etc) doesn't seem to have this odd ROM copy problem at all...
So :
REV 5 not ok (this one is
@coonsgm ) board, So I don't know if there are other issues at play yet, or its just the board rev.
REV 5.50 (hacked up res mods) seems ok
REV 5.50 (no mods other than 3.3V wire) seems ok
REV 5.62 seems ok
EDIT2:
So
@coonsgm board only seems to act up when TTram is enabled. But I just noticed it has Alience RAM.. so that's probably why..
