Page 10 of 26
Re: TF1260 New Firmware Alpha Released!
Posted: 20 Dec 2021 13:43
by terriblefire
voscoboss wrote: 20 Dec 2021 13:40 I'm at a total loss as to why my amiga isn't booting with the new firmware(s). Hanging reset line doesn't seem to be the issue. Probably something wrong with my setup, as it seems I'm the only one with a reAmiga board and this issue.
Back to beta for now. Will investigate further once I have another Amiga and/or other PSU to test with.
If you speak to @chucky you can return it for a known working one. My guess is there is bad solder joint on something else that wasnt used by the old beta.
Posted: 20 Dec 2021 15:15
by Duncan
If any of you are using Scalos, it's a doddle to setup a wee right click drop down menu, to change the speed on the fly, looks nice to :)
Posted: 20 Dec 2021 15:24
by CrazyC
Another nice touch would be an environment variable for the CPUspeed so under 3.2 it could be shown in the titlebar, just as a reminder as to what speed you are currently running (sorry for drifting off topic a little).
Posted: 20 Dec 2021 15:41
by chucky
terriblefire wrote: 20 Dec 2021 13:43 If you speak to @chucky you can return it for a known working one. My guess is there is bad solder joint on something else that wasnt used by the old beta.
replacementboard going out tomorrow :)
Posted: 20 Dec 2021 16:56
by amiga-peter
Unfortunately new FW with rev. 5 68060 is very unstable.
Only 50MHz works.
Is it possible to check if FW upgrade was successful?
Peter
Posted: 20 Dec 2021 17:13
by terriblefire
amiga-peter wrote: 20 Dec 2021 16:56 Unfortunately new FW with rev. 5 68060 is very unstable.
Only 50MHz works.
Peter
50Mhz is unstable?
Posted: 20 Dec 2021 17:23
by alenppc
Only 50MHz works.
Peter
Not every CPU likes to be overclocked... 50 Mhz is the only guarantee, all the rest is a bonus.
by matt020
Only 50MHz works.
Peter
Can I chime in and say here that I thought I had a problem with my Rev 5 when it would not up clock any higher than 50mhz. Anything above 50 would crash, but there was a reason...... I was using the wrong version of CPUSPEED. Very important to check. I am not a dumb arse, but I was just too excited and overlooked this step. Once I used the new version of CPUSPEED, I had success in changing speed.
Posted: 20 Dec 2021 17:37
by supaduper
I have a Rev 5 and it is picky with CF cards, with the Cheapo one is like yours it only runs at 50mhz but with a Quality Transend it runs at 63mhz no probs,
So make sure you try a couple of different CF cards as our Amiga`s can be `Funky` with some CF `s :)
And as Matt says make sure you have replaced the CPUSPEED program that comes with the Firmware with the one already on your system ( Normally found in C: )
Posted: 20 Dec 2021 19:35
by Cego
@terriblefire
i was wondering if you could get more into the technical detail why overclocking fails at some clocks with the current state of the FW?
I find it interesting that only 50MHz, 84MHz and 100MHz work stable on my machine, while almost everybody can clock his card to 66MHz but mine fails.
Does the A1200s all have crappy and slightly different timing or what's the secret behind this behavior?
Thank you!
