Page 10 of 11
Re: Cartridge keys and emulation
Posted: 21 Feb 2022 19:09
by DoG
Cyprian wrote: 21 Feb 2022 18:59 That is not mine, I've just found it on AF
Yes, of course. I shouldn't have quoted you. The question is for everyone on the forum. :D
I tried a bit of googling, eBay and checking in XgPro (TL866 programmer) if it could handle it. Not much to be found but I didn't spend a lot of time on it.
Posted: 21 Feb 2022 20:57
by UnnamedVillain
Use for example ALL-07, Labtool-48, Chipmaster6000, AllPro-88 or similar programmer from the past :)
Posted: 22 Feb 2022 00:13
by troed
DoG wrote: 21 Feb 2022 18:57 How do you program an Altera EP600 or an Intel 5C060?
I spent some time researching that this evening. You either buy used original equipment - around 100€ should do it - or you buy a modern programmer that's able to. That option seems to run you 1000-2000€.
Will look at UV's suggestion tomorrow - hopefully a bit easier to swallow.
(decompiled .jed posted over on the other forum for no obvious reason)
Posted: 22 Feb 2022 19:59
by Dave345
There's a patch been created, it appears to work in software so next step hopefully is to write to hardware.
Posted: 27 Feb 2022 13:46
by troed
Steinberg Masterscore. Blue dongle, but it's exactly the same (PCB, IC) as black dongle Avalon, for example.
Posted: 01 Mar 2022 17:17
by troed
I've now implemented two pieces of software: "dumper" and "dongle emulator". The first will extract, by running on an ST with the original Masterscore dongle inserted, a bunch of data. Note that this is not the "equations" that would allow anybody to make a clone of the dongle. It's more like the results of doing challenge-response queries to the dongle.
The emulator then patches the Masterscore program, and any files it in turn loads, to talk to itself rather than a dongle. The emulator makes use of the data grabbed by the dumper to present exactly the same responses to the original program as a dongle would've.
And as far as I can see this is working perfectly. I can click on anything in Masterscore while running it in Hatari and it all works.
"My" challenge is now to generalize these so that I won't need to create one new set of programs for every original program/dongle pair. I still have some work to do there.
However, I consider the original thesis - inspired by the works of beel1 - to have been proven. It's fully possible to preserve working "black/blue" dongles so that the owners of original programs can keep using them, whether it's on original hardware or in ST emulators with midi support (like Hatari).
/Troed
Posted: 01 Mar 2022 21:42
by JezC
@troed That's fabulous progress!
I have a number of original Steinberg & C-Lab dongles for use on my real Ataris...but having the option to run the protected s/w under emulation will be a great help when trying some ideas out!
:thumbup:
Posted: 02 Mar 2022 18:41
by troed
Unfortunately I think I only have one working dongle of suitable version - Masterscore. Just sent off a beta version of the app intended for Masterscore to someone for test. I should be able to make a version of the app for any other software, I think, but can't test it myself. Since I have the Avalon sw I could try with that if you have that dongle?
Cubase 3, Cubase Audio, C-Lab Creator are 'new version'. Those need decapping by Talented Polish Hackers ;)
/Troed
Posted: 02 Mar 2022 21:19
by JezC
troed wrote: 02 Mar 2022 18:41 Unfortunately I think I only have one working dongle of suitable version - Masterscore. Just sent off a beta version of the app intended for Masterscore to someone for test. I should be able to make a version of the app for any other software, I think, but can't test it myself. Since I have the Avalon sw I could try with that if you have that dongle?
/Troed
Yes, I have an Avalon dongle (along with Steinberg Syntworks M1 & DX/TX-7, 24 & possibly one Cubase 2), so happy to try it out.
Probably best to let me know how you are running the emulation on PC...or I can just run it on my ST without the dongle connected.
Posted: 05 Mar 2022 15:37
by troed
Current status (app is in beta test, not generally available):
*) Masterscore - the one I have a dongle for myself. Works well.
*) Avalon - I don't have a dongle. It talks to the dongle emu, but someone with a dongle needed to verify/get further.
*) Cubase 2 - I don't have a dongle. It talks to the dongle emu, but someone with a dongle needed to verify/get further.
While the actual protection routines are so similar between the apps above that I use the exact same code to interact with the dongle/app, they are quite different in how they work otherwise. Cubase 2 had a lot more effort put into its protection. It's still my opinion that once I've enabled a few apps and they're working fine the rest should just follow without needing to do anything separately for them.
/Troed
