Page 10 of 11
Re: Random STuff
Posted: 23 Jul 2022 18:55
by DoG
Woohoo. So nice to have a newly cleaned desoldering gun! Peace of mind. "clean mind.... eeer... clea.. clear.. er... something".
- Cleaned desoldering gun.jpg (261.34 KiB) Viewed 3318 times
Re: Random STuff
Posted: 04 Aug 2022 15:13
by DoG
Got some more Eiffel done. All tested and working.
- 2022-08-04 16.00.44.jpg (306.36 KiB) Viewed 3274 times
Re: Random STuff
Posted: 16 Aug 2022 18:37
by DoG
I "needed" an adaptor for an
Inventronik ACSI-SCSI board I have. I already done an
IDC20-ACSI so I used that as a part of the design to connect to my MegaST. Adapter is a IDC26-IDC20 and a BERG 4-pin connector. But I'm unsure if you could drive the board thru that. It's probably for termination power so I didn't use that and neither should you. But it is there, so deal with it... If you, for some Godforsaken reason, need this, the gerbers and the Eagle files is down below.
- Inventronik IDC26-IDC20 bottom.jpg (107.98 KiB) Viewed 3212 times
- ACSI-BlueSCSI.jpg (250.38 KiB) Viewed 3212 times
Re: Random STuff
Posted: 16 Aug 2022 18:45
by DoG
Here is it all connected and the speed is not the greatest.
- All connected.jpg (556.92 KiB) Viewed 3212 times
- BlueSCSI thru a lot of adapters.jpg (442.72 KiB) Viewed 3212 times
Re: Random STuff
Posted: 10 Nov 2022 10:18
by DoG
I have made and ordered a PCB for C Zietz
WiFi/SNTP clock for Atari with DB25 serial port. For fitting in a
DB25 shell hopefully.
- Wifi-SNTP Clock top.png (38.59 KiB) Viewed 3018 times
- Wifi-SNTP Clock bottom.png (44.08 KiB) Viewed 3018 times
I bought some 100ml needle nose flask to have my liquid flux in since I kept tipping the other ones over and spilling it everywhere (Topnik brush flask). I have been using this for a while now. Works great.
- Needle nose flask small.jpg (11.31 KiB) Viewed 3018 times
Re: Random STuff
Posted: 10 Nov 2022 10:25
DoG wrote: 10 Nov 2022 10:18
[/b]I bought some 100ml needle nose flask to have my liquid flux in since I kept tipping the other ones over and spilling it everywhere (Topnik brush flask). I have been using this for a while now. Works great.
Nice PCBs sir.
I use those bottles for the likes of 3in1 oil (They are a bit handier than the 3in1 bottle)and contact cleaner as the aerosol is a bit too vigorous!!
I haven't tried Topnik in one, I'll give it a whirl, but my preference is for the brush, though I get what you say about knocking it over!!
What I do really like are flux pens with a fibre tip, they're great, and you've just reminded me I need to order a new one :)
Re: Random STuff
Posted: 28 Nov 2022 16:36
by DoG
Dry fitting seems to be alright in the shell and I can even close it. I don't know if micro USB connector will fit since I don't know where they are at the moment.
EDIT: Apparently I didn't order the USB connectors. I wish I had made the board 1mm longer as well, but hopefully it will work anyway. Maybe a v1.2 perhaps. :D
- 2022-11-28 16.29.42.jpg (319.35 KiB) Viewed 2944 times
Re: Random STuff
Posted: 10 Dec 2022 18:46
by DoG
Re: Random STuff
Posted: 23 Apr 2023 18:58
by DoG
I soldered the last bits on a BlueSCSI v2 (programmed the Pico as well of course) and tested on a remake board. I used the Inventronik adapter in between so it's probably/maybe it that drags the speed down since BlueSCSI v2 can go faster.
- BlueSCSI_v2_with_Inventronik_adapter.jpg (470.16 KiB) Viewed 2609 times
- BlueSCSI_v2_XferRate.jpg (118.65 KiB) Viewed 2609 times
Re: Random STuff
Posted: 11 Nov 2023 17:55
by DoG
Soldered and programmed a Cubase Audio Dual Dongle.
- cubase dual dongle DoG small.jpg (55.44 KiB) Viewed 2251 times
