Page 10 of 95
Re: FMNs blog / the latest things hes briken(fixed)
Posted: 14 Aug 2019 10:39
by PhilC
You guys are presuming I had s choice in the names. I'm married, what does that tell you :lol:
And yes, it was an STE which I was going to clean up and resell. 1040ste with 2mb.
Posted: 14 Aug 2019 13:54
PhilC wrote: 14 Aug 2019 10:39
So you didn't even have the illusion of choice?
Posted: 14 Aug 2019 14:29
by PhilC
rubber_jonnie wrote: 14 Aug 2019 13:54
You are married too arent you. :P :lol:
Posted: 14 Aug 2019 15:08
PhilC wrote: 14 Aug 2019 14:29
I am. I don't have the illusion of choice either :dizzy:
Posted: 14 Aug 2019 15:35
#AmericanGothic
Posted: 22 Aug 2019 16:48
by PhilC
Been doing a special project that involved me breaking things again lately but still on the desk was my Amiga 500+
It now has 2mb of chip ram and I've assembled myself a simple external got adaptor, which seems to work pretty well with the flash floppy drive I have.
I've just found some WB3.1 disks which I'm in the process of turning into real floppies again, thanks to an ancient copy of X-Copy pro :)
The good news is the internal drive works pretty well, as does everything else I've tried so far too to be honest. The only thing really letting this Amiga down is its rather inconsistent sun tan but a good dose of retrobrite at some point will sort that out.
Still on the Amiga todo list is to fit the new battery once it arrives. I went for a Nimh one with the same footprint as the original one. Then it's to acquire a TF accelerator of some kind. I have a 534 at the moment but it was all set up for an Atari, so may just get another at some point.
Hopefully the TF card will then get me set up with an Amiga HD. Not installed a HD on an Amiga since..... I can't remember :shock:
On the Atari front I've been fixing up a couple more STFM boards. Got myself a 512k board with Tos 1.04 in two chips, which is a first for me. SO will probably upgrade that to 1mb and sell it on. Any Takers?
Then there's the broken Atari STE I got the other day, I've now got another case. It's a 520STe case this time but as you lot know, it all fits.
Need to have a clearout of some of my STFMs but its hard to know what to part with but there's only so many Ataris I can use and the majority of them are either Test boards for Icky and expos projects or my Mega Sts, the rest don't really get used.
In other news.... These two puppies are doing their best to destroy everything. Needless to say, the geek room door stays well and truly closed :D
Posted: 23 Aug 2019 21:41
by PhilC
The new Amiga battery arrived today. It too longer to get the corroded lead out the board than it did to solder the new one in.
Then it took me over an hour to find some Workbebch 2 disks. WB3.1 easy to info, 2.0 not so much.
Anyway , the battery is done and the clock even remembers the time and date :lol:
Got my GBS8200s today. Will have to have a good look at these. They supposedly change Sega6, CGA rgb etc to VGA. I wonder if they will let me use my Atari 800s on the VGA. Some googling for a guide required.
Posted: 26 Aug 2019 13:16
by IngoQ
PhilC wrote: 23 Aug 2019 21:41
Eagerly awaiting your reports on this. I currently use a Framemeister for almost everything, but it has it's shortcomings... Especially on the Amiga, the mode switching delays are really annoying.
Posted: 26 Aug 2019 15:26
by PhilC
IngoQ wrote: 26 Aug 2019 13:16
I'm waiting on some more D connectors to make up a proper lead for it. I tried the VGA adaptor lead I'm made to go straight to my NEC but that doesn't work.
Will post an update once I've done it :)
Posted: 26 Aug 2019 15:43
by IngoQ
PhilC wrote: 26 Aug 2019 15:26
Strange, it should have. I have a 1970nxp and it handled almost all the PAL modes, although not very pretty. It lacks some image adjustments, so I went back to the Framemeister. With that I went with DoublePAL in 640x512 interlaced for the Workbench. The Framemeisters deinterlacer works that flawlessly that you hardly notice any comb artefacts at all. Since the NEC is native 1280x1024, I can integer scale 640x512 to achieve almost perfect pixel mapping.
Did that just yesterday, when I wanted to play a round of Menace and ended up spending half the day adjusting display settings ;)
Looking great now, but when you launch a game or a demo it takes forever to sync, that's the main downside. I was thinking to put an Indivision in my A1200, but that would only be a solution for ONE machine ;)
