Page 10 of 28
Re: Video driver thoughts
Posted: 27 Nov 2018 00:41
by PaulJ
Icky wrote: 26 Nov 2018 23:42
exxos wrote: 26 Nov 2018 22:50
Hot coco then bed for you me thinks ;)
Call me Mr McShaky Hands.
Got the board soldered it needs a clean up from all the flux but the harder I tried to keep a steady hand the worse it got.
Notice the small cap nearest the big ones and its wonky but has connectivity - I gave up on presentation skills.
Now I'm going to get a hot coco Exxos.
Testing in the morning.
:thumbup: :thumbup: :thumbup:
Posted: 27 Nov 2018 11:40
by Icky
I think this is a 5 storey building.
I count the main board DIL. A stack of 2 DIL's. The row of SILs and the socket for the shifter.
My PSU on stilts is still not tall enough. The jumper and connector are too high. I'll change them to be right angles as this will be enough to allow the PSU to go back in place.
- IMG_3318.png (405 KiB) Viewed 3933 times
Posted: 27 Nov 2018 12:23
by Icky
Damn the 33R resistors R19, R23 & R30 are now under the monitor & floppy un-f*ck boards. A bit of fiddly work ahead me thinks.
Posted: 27 Nov 2018 13:06
by PhilC
But more opportunity to hot snot later.
What do you need to do with the resistors?
Not progressed very far with mine as got given work to do.
Posted: 27 Nov 2018 13:19
by Icky
Forgottenmyname wrote: 27 Nov 2018 13:06
The resistors are the entry point for RGB to the monitor socket. Need to patch the connector on the Video DAC board to these points.
I am putting in jumper leads so I can go back to the original design if needed
Posted: 27 Nov 2018 13:34
by PhilC
Sounds like a plan, will follow your lead when back home later.
Posted: 27 Nov 2018 14:51
by Icky
This is how I have jumpered the RGB lines. Taking the RGB and the 33R lines out to the top of the board. Yet to hot snot it to make it secure.
- IMG_3322.png (135.2 KiB) Viewed 3911 times
Top of the board I can connect the RGB lines together from the bottom of the board to continue as the original design or connect to the Video DAC board (connectors in pic on Video DAC board may not be right as I haven't checked the correct RGB out from the board)
- IMG_3324.png (515.13 KiB) Viewed 3911 times
Posted: 27 Nov 2018 17:24
by Icky
First power on and we got a black screen when it should be white at boot then the desktop finally arrived it is almost there.
Am going to do a check over the board incase my soldering is rubbish etc
- IMG_3327.png (582.76 KiB) Viewed 3902 times
Posted: 27 Nov 2018 17:27
Icky wrote: 27 Nov 2018 17:24
That is some funky stuff! Those jumpers should adjust the brightness...
Posted: 27 Nov 2018 17:53
by Icky
exxos wrote: 27 Nov 2018 17:27
Jumpers make no difference.
Am still going over my soldering and checking all the connections etc.
