Activity on D0-D2 (didn't check others) but a LOT of cycles going on now!
Re: Fixing my Milan 040 (or not) blog
Posted: 24 Jun 2025 13:52
by dml
Did you make backup the flash with the TL866 before writing? (In case the other programmer was misbehaving - since it wasn't erasing properly?)
Posted: 24 Jun 2025 13:55
by dml
Beeping seems like a step forward :p presumably it can only beep if it managed a lot of other stuff first.
dml wrote: 24 Jun 2025 13:52
Nope.. Because it verified exactly as the bootblock anyway, so I didn't see any need to back it up.
Posted: 24 Jun 2025 13:57
dml wrote: 24 Jun 2025 13:55
Indeed :)
I suppose constant beeping is error for some idiot removed a lot of stuff from the motherboard :P
Posted: 24 Jun 2025 13:58
by dml
exxos wrote: 24 Jun 2025 13:55
:thumbsup: was really just in case the positions/offsets of things turned out to be correct after all but that seems unlikely now, given the beeps!
Can't tell from the video but are the ICs still missing or did you put them back? Would be cool to see some POST output from the ISA bus next
Posted: 24 Jun 2025 14:00
dml wrote: 24 Jun 2025 13:58
The large IC is still missing, ordered from Poland so waiting for it to arrive.
I could plug a graphics card in, but I don't know if any work at this point.
Posted: 24 Jun 2025 14:01
Current "view".
Posted: 24 Jun 2025 14:16
by PhilC
Id try and et4000ax graphics card if you've got one @exxos as those are the default for EmuTos and others. Even if you get a synced output you know you're going the right way
Posted: 24 Jun 2025 14:17
PhilC wrote: 24 Jun 2025 14:16
Uwe said a S3 trio chipset will work.. I have one of those and 2 others of what I can find..
