I have gone back to the IDT chip to do more tests with pull-ups on the 3.3V side...
Chip is powered from 5V, via a diode (as suggested in the document ) which gives 4.2V actual chip VCC.
- d.JPG (43.88 KiB) Viewed 5871 times
1.1K pull-up, I get 3.85V
2.2K pull-up, I get 4.13 V.
10K pull-up, I get 4.65 V.
I also tried some pull downs..
10K pull-down, I get 4.06V.
1.1K pull-down, I get 1.66V.
There is a chart which mentions resistor values, it does not seem to actually mention is relevant to :roll: It does seem as they mention though, the higher the load, the higher the voltage drop.. But this still does not seem to be correct as I should be seeing 3.3V on the output surely ?!
- qs.JPG (85.56 KiB) Viewed 5871 times
This is the info about the chip...
- 2.JPG (13.92 KiB) Viewed 5871 times
- 1.JPG (33.39 KiB) Viewed 5871 times
Saying A & B are solidly connected, that does seem apparent to me, but also I see 5V input and 5V output..
But then the datasheet then says the output is clamped to 4V ?! Obviously this does not happen as I get 5V! If anything it should be 4.2V as that is what is on VCC of the chip.
Current setup...
- idt.jpg (104.63 KiB) Viewed 5871 times
So I don't think the resistors are actually the solution here.. This just seems to be loading the to the point that the voltage drops..
The chip itself should inherently somehow limit the output voltage, but even so, 4V is still to high for 3.3V work.
So I think I am going to see if I can find some other chip which is equivalent to this one and see if there some better information on it...
Also going to run some more simulations on the MOSFET version...
Here it is... working fine ?!
- sim.JPG (114.25 KiB) Viewed 5866 times
To be continued....
