Page 9 of 16
Re: A Grand Day Out
Posted: 17 Feb 2024 11:14
Well, that was a pleasant surprise. The PLA and MMU just appeared via the postie, which I wasn't expecting since I only got the eBay email saying they were dispatched this morning!!
So the desolder gun is warming up and we'll get this old one swapped out :)
Could be a good day as the PAL <=> NTSC adapter for the OSI should be here later on, and possibly the SD card cassette for the MZ-700 too :)
Re: A Grand Day Out
Posted: 17 Feb 2024 11:48
by PhilC
@rubber_jonnie should be a fun and productive day for you
Re: A Grand Day Out
Posted: 17 Feb 2024 12:18
PhilC wrote: 17 Feb 2024 11:48 @rubber_jonnie should be a fun and productive day for you
Nice quick change thanks to the desoldering gun:
Or as some YouTubers like to call it, 'The Moo Gun'.
Very glad I got a replacement gun for my base unit, it works really well and cleared the holes so well I just needed a tiny bit of heat on one pin to get the old PLA out.
Turns out the PLA isn't at fault though, or the MMU. I've swapped both and whilst I can still get into C64 mode using the boot time keypress, C128 mode is just not happy, with a blank screen most of the time, and neither run the diag carts anymore. Or any carts for that matter.
I swapped the PLA and MMU back to the old ones and it's just the same, and I can't shake the feeling that handling the board made it worse, so could it be a mechanical issue like a dry joint?
I'll come back to it later and probably Electrolube all the sockets that I haven't yet done and give the underside a really close look.
Right now though, I need to walk the dog :)
Re: A Grand Day Out
Posted: 17 Feb 2024 12:39
by PhilC
@rubber_jonnie swap out the single wipe socket of the mmu. I bet it’s that as I’ve seen that behaviour before.
Re: A Grand Day Out
Posted: 17 Feb 2024 12:49
PhilC wrote: 17 Feb 2024 12:39 @rubber_jonnie swap out the single wipe socket of the mmu. I bet it’s that as I’ve seen that behaviour before.
Hmm, I thought it was a double wipe, but I'll check later, thanks.
Re: A Grand Day Out
Posted: 17 Feb 2024 13:07
by PhilC
My whole board was a single wipe, hopefully you’re luckier.
Re: A Grand Day Out
Posted: 17 Feb 2024 13:29
by stephen_usher
I hope it's a simple fix. I guess that there's a whole load of buzzing out traces in your future.
Re: A Grand Day Out
Posted: 17 Feb 2024 13:40
by PhilC
stephen_usher wrote: 17 Feb 2024 13:29 I hope it's a simple fix. I guess that there's a whole load of buzzing out traces in your future.
Me too, it looked to be a simple fix when I sold it.
Particularly troublesome chips I found on those C128 boards were the 74LS 06, 08. 257.& 244s
I can give you a few tips if needed but without the MMU doing its thing you won’t get much else
Re: A Grand Day Out
Posted: 17 Feb 2024 13:49
PhilC wrote: 17 Feb 2024 13:40
Honestly, I don't mind as I knew it wasn't 100%, and I enjoy the fault finding side of things.
I'll start by looking at all the sockets and see how they're doing, take it from there.
Re: A Grand Day Out
Posted: 17 Feb 2024 13:50
by stephen_usher
244s are always iffy. :-)
